converting jet to bravo 1
Results 1 to 7 of 7
    Senior Member 79sleek's Avatar
    May 2011
    Wyoming
    Default converting jet to bravo 1
    has anyone ever converted their jet to a mercruiser bravo or alpha?
    Alamogordo NM
    Default thought about it
    I have tought about it, the only potential problem i see is the different heights of the centerline of the crank in refence to the bottom of the keel. A I/O unit could hang pretty far below the bottom of the boat. Could work though.
    Ladera Ranch
    I thought about it. To do it right would not be cheap. On my hull it would require lots of work to the transom to make it strong enough to support the weight. Decided Id find a new boat if I wanted an outdrive.
    Senior Member slow67's Avatar
    DFW
    You also need to add several inches of thickness to the transom.
    I think I would keep the Jet, Jets haul a$$ & it seems like it would be a lot of fun to drive one like a seadoo,turn hard & spin out.
    My family boat has a outdrive but its 24`-00" & we use it on Lake Havasu but it doesn`t leave hard. Probably in the long run it would be cheaper just to find a out drive boat instead of converting a jet not to mention work better too!!
    Quote Originally Posted by 79sleek View Post
    We usually get requests to do the opposite
    May 2011
    Wyoming
    was just wondering i do like my jet because it runs in shallow water great can go places no one else can lol unless they got a jet too ill just have to get a deverter and a turbo lol
