Impeller???
Results 1 to 5 of 5
Impeller???
    Jul 2009
    Default Impeller???
    Hi, can anyone tell me what this impeller is made of? I had it in a pump, and sent it out before I could give it a good look over. I was told its alumnum, but I have only seen the Berkeley impellers, that are painted with that green coating.
    Angier, NC
    alum. your right
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Jul 2009
    So. OC, Ca
    Default Looks like bronze
    The portion of the impellor next to the nut looks more like bronze than aluminum to me.
    you can weigh it, aluminum impellor will be in the 4-5 lb range, bronze and stainless 12-14 lbs.
    California
    Looks like it might be an early 90's Dominator Aluminum. Also looks like the stuffer ring was machined off the back side furthering my suspicion. They were a gold anodized in color and most would also have a year stamp next to the cut stamp near the inner hub.
