Nozzle suggestions
Results 1 to 2 of 2
Nozzle suggestions
    Default Nozzle suggestions
    Hello all, I just got the new split bowl installed in my Glastron CV19 and have run into a problem. The length of the bowl and nozzle adapter has increased enough that the reverse cable no longer fits in the slot through the swim platform. I know that place sells a low profile system, but not sure if that will fit under the platform either. I'm wondering if the standard place nozzle will move the reverse cable far enough aft that it can sit entirely outside of the platform, instead of in the slot like it was from the factory? Would anyone be willing to measure the distance from the nozzle adapter to the reverse cable attachment bracket on a standard hydraulic Place for me? If I get a new Place low profile system, how in the world would the reverse cable make the bend under the platform down to the bracket? Anyone have any pics of the reverse cable setup on the Place LPS setup? In the pics you can see where the reverse cable is now hitting the swim platform at about 50% steering angle. What do you all think would be the best way to proceed?
    Thanks,
    Tim
ID:	116938   Click image for larger version.
    Lake Havasu
    Here is a picture of how I routed my reverse cable. I have never been a fan of the big loop. This is the low place diverter.
