race pumps fuel pump
Results 1 to 14 of 16
    triple digit sightseer redcat's Avatar
    Mar 2010
    CENTRAL WISCONSIN
    Default race pumps fuel pump
    so i just got my race pumps.com fuel pump back from an update rebuild for my bbc, installed it back on the engine and go to fire it up and have fuel pouring out of the vent hole on the front side of the pump. its almost like they forgot to put some orings back in the pump... i heard somewhere that new pumps don't have the vent hole and they no longer use orings in tip... did they forget to plug the hole or just screw up the rebuild? any one have any ideas? thanks... and so much for being on the water this holiday weekend...
    Dec 2010
    Sapulpa ok
    Screwed up. What pump ?
    RAT PATROL rich s's Avatar
    S central Pa.
    when this has happened to me, it was a bad diaphragm, it is a fairly strait forward repair.I always had a spare with me in the truck so it can done in a short period of time rather than shipping it out.
    okie, lake Texoma
    That pump doesnt have a diaphram, you'll need to talk to Howard and see what he has to say. He will make it right if something wasnt done correctly. You must have an older design pump. All the ones i've had my hands on dont have a vent hole.
    H8-2-W8
    [email protected] first pass
    S central Pa.
    my bad I was thinking of a super flow/magna fuel, electric pump, carry on
    Shell Knob, MO
    When you say
    Are you using the term as race pumps in general, or are you talking about the True Race Pumps that you see on
    Race Pumps Fuel Systems
    Duane HTP
    Mar 2010
    CENTRAL WISCONSIN
    When you say
    Duane HTP
    yes i am referring to a true racepumps.com brand fuel pump for a bbc.
    Shell Knob, MO
    I've never seen a vent hole on one. That's why I ask. Send it back to them. they will make it right. Good people to deal with.
    Duane HTP
    Mar 2010
    CENTRAL WISCONSIN
    Default racepump update
    i wasn't very impressed with the customer service i had on the phone, more like accusing me of not installing it properly, they wouldn't prepay shipping back to fix it either...
    so i finally got the pump back nearly a month after sending it out again, i will be installing it later today to see if its actually fixed...
    overall, NOT an enjoyable experience, i know i will not be doing any more business with them in the future.
    i do want to thank fellow member Fonz69 for the use of his race pump to get the boat back on the water until the issues with mine were resolved.
    Don't Member Blow It Up's Avatar
    Sep 2009
    Yucca Valley
    I have a race pump. I'm curious what they said was the matter with yours?
    okie, lake Texoma
    Me too, cause mine has been great, and if you ask to talk directly to Howard Steward he is very helpful and a pleasure to do business with. Their customer relations have been top notch as far as I'm concerned.
    H8-2-W8
    Mar 2010
    CENTRAL WISCONSIN
    my pump was "updated" to their new specs two years ago. had a problem with the pump wearing out the o-rings on the plunger shaft engine side within a couple hours of use after a new o-ring kit... called them up, explained the situation, they said to send it in and they'd look at it... afterwards on the phone, when i was paying for it, i was told it was the old design and that it needed the update kit installed...(which the pump already had done to it, i have the receipt) i was also told that they had a run of some bad o-rings from the same time frame, which my rebuild kits came from too... so whether it had bad o-rings or something damaged inside or ??? i don't know for sure...
    after sending the pump back in the second time due to the massive fuel leak upon re-install, i never got a straight answer, but it sounded like they forgot to put some o-rings back in the pump when they did the rebuild.
    also, i never got a chance to install the re-rebuilt pump today to see if it's actually fixed, instead i ended up at the hospital awaiting the arrival of my first child...
    Colorado Springs
    Quote Originally Posted by redcat View Post
    Hey John. New rug rat????? I ran that pump for two seasons with zero troubles until you bought the boat, oh yea I kinda miss it now. How did you or where did you get the pic of what was my boat in your avatar?? Can you steal pics form me off this sight?? Well anyhow maybe I am jealous that I couldn't figure out how to do it. Oh yea just finished with a weeks worth of hot sticking H structure 69KV crossarms, pretty fuzzy. We are still looking for one lineman and two if I can figure a way to move to Missouri. still haven't sent your plates.
    If the pic is on the internet, you can pretty much move it anywhere you like.
    The racepump is kind of like a magneto, and a shopping cart. Sometimes you get a good one, sometimes you don't. Right Hass?
