BBC, need length of 3 point bellhousing - help!
Results 1 to 8 of 8
    Jan 2010
    PA
    Default BBC, need length of 3 point bellhousing - help!
    thanks for any help,
    Mounting my engine, just realized the bellhousing is too short for the H driveline. (1310 driveline "extends out of the bellhousing" and would be too deep into the berkeley jet) bellhousing itself should be an inch or so longer?
    Anyone know how long the CP performance bellhousing is? looking at buying the BBC 3 Point Bellhousing 620-91150
    does anyone have a used belhousing for sale?
    Angier, NC
    Default lenght
    u have to make sure u have the right shalf for the bellhsing they are different
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    Jan 2010
    PA
    yes, copy that. figure its easier to match the bellhousing to my driveline, then driveline to my bellhousing at this point. never had this issue before. figured these 3 point behousings were pretty much the same, obviously not. I know I have a standard H-bar setup, bought those parts new from CP. just need to get smart on lengths.
    Senior Member wolfie's Avatar
    Give Tom at Jet Boat Performance a call. He'll get you set up right.
    I have a 9 1/2 " bell housing .Measure the depth of yours and see if this one will worl $ 150.00+ shipping
    Quote Originally Posted by Frank View Post
    Frank the short B'hsg which works with the rockwell D/L is a smidge over 7 and the long (for a 1310 spicer is just over 9" call if you need help Tom
    Oct 2013
    sold! do you have a PayPal account?
    Oct 2013
    Default do you still have this?
    Sold! do you have a paypal account?
