Olds 455 running rough....
Results 1 to 2 of 2
    Idaho Jet Craig4937's Avatar
    Aug 2009
    Default Olds 455 running rough....
    I have an olds 455 that I just purchased. I replaced the intake and dist. and ignition box. Went to fire it up and I can't get it to idle and It is running rough. When i installed the new dist. I took the #1 cyl. spark plug out & got it on the comp. stroke, pointed the rotor at the #1 cyl and the rotated the cap at the #1 position.
    Any Ideas?
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Quote Originally Posted by Craig4937 View Post
    Any Ideas?
    Check firing order. 1-8-4-3-6-5-7-2
    Timing can be 180* out
    Wikus
