Jet Pump Question
Results 1 to 8 of 8
Jet Pump Question
    Senior Member Cobra 02's Avatar
    Montclair
    Default Jet Pump Question
    A friend of mine need entirely new inerds of a Barracuda jet pump, Model BJD-33, I myself never heard of them, who make's them and were can I get parts for it, do any other pump Mgfs. make interchange parts for them. Thanks in advance.
    B1 Racing cs19's Avatar
    Quote Originally Posted by Cobra 02 View Post
    Other parts will fit in there, what exactly failed on it?
    Montclair
    Pretty much everything, Im guessing it started 2 summers ago with the bearing seals in the bowl and just moved forward from there until it completely locked up on him.
    He basicly needs everything inside new...
    Did it tear up the suction housing?
    Baracuda was a short lived manufacturer , and as said some Berk/AT parts will interchange call or have your Bud call if Josh or I can help !Tom
    its just another day DK_Hallet's Avatar
    El Cajon CA
    Default Just picked up a boat with a Barracuda also
    Just picked up a Boat with a Baracuda also . Biggest question . How hard would it be to switch this out with a A / T or Berk Pump ? Dont know if the intakes are the same and so on . Thanks
    Something Wicked This Way Comes
    Quote Originally Posted by DK_Hallet View Post
    The Baracudas and the other jets you mention are very similar and can share alot of the same repair parts , the bolt patterns on the suction to intake are quite somewhat different Tom
    Anaheim Hills
    Old thread, but do you guys who have Barracudas, have intakes that look like this? This is what that shape of my intake looks like.
    https://jetpumpparts.com/intake-suct...category_id=91
    I'm pretty sure American Turbine works on the Barracuda intake. I was also able to use an Aggressor droop snoot.
