[Question] impeller removal with jet a way
    small block jet 2sangers's Avatar
    Lexington SC
    Default impeller removal with jet a way
    Just wondering what you racers do when changing / checking impellers to remove the nut. New set up problem for me since installing the jet a way.
    Shell Knob, MO
    Use a 1 13/16" deep socket on a 3/4" impact wrench.
    Duane HTP
    Lexington SC
    Thanks,
    Looks like we need a bigger rig for Augusta. I know it is supposed to be dialed in before race day but we're still rigging
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Yep, I just pulled my pump apart yesterday for inspection. Impact gun with the correct socket simply hold the impeller with your hand. When putting it back on I do the same, I just hit it with the impact for a min or so to make sure it's tight.
