hydraulic diverter question
Results 1 to 10 of 10
    gets 'em wet ultrajet's Avatar
    folsom, ca
    Default hydraulic diverter question
    My diverter has been a little hesitant lately and at times just won't budge at all. After bleeding the lines a little it seems to work like a champ once again. Anybody have similar problems in past and what kind of general maintenance outside of maintaining fluid level is required for these things?? My diverter is from AT with Bennett pump. Any thoughts?? Thanks guys!
    Anaheim Hills
    Quote Originally Posted by ultrajet View Post
    I used to have issues with mine bouncing out of the cheap plastic mount falling over and draining all the ATF in the bilge and it wouldn't work.
    So I bought one of these.
    Feb 2009
    MANTECA
    Default Pump
    I thought that the bennet pumps were self priming, but mine didn't seem to self prime either.
    whats a goodtime cost? Nixonnow's Avatar
    Feb 2011
    Fort Mohave, Arizona
    rivertrash where oh where did you get that. i also have a hyd place diverter and have worried about the plastic mount breaking. thanks.
    Senior Member cave's Avatar
    Mesa, AZ
    Do you have a relay connected? The Bennett pump requires 12 full volts to operate correctly. Also The ground must be a good ground or the pump will burn itself up.
    I got a Baderlog relay on the Kachina and a Bosch type relay on the Liberator. I replace the Bosch relay once a year. They don't like moisture. I also carry a spare. The Banderlog unit just keeps going.
    Takin it home
    folsom, ca
    There must be some relay since I can run it direct from battery but it's not Banderlog. I was thinking maybe air is getting in the lines or something. Haven't ever had a problem with it 'till now.
    Anaheim Hills
    Quote Originally Posted by Nixonnow View Post
    Ebay. I think it was around $50
    Feb 2011
    Oh ok. Was expecting something like Rex marine or Dana marine or something. Lol ill keep an eye on ebay though.
    Anaheim Hills
    Billet aluminum bracket place diverter pump jet boat | eBay
    Feb 2011
    hell yeah bro. thank you for that.
    note: sorry for the thread jack ultrajet
