My ski pole build
Results 1 to 9 of 9
My ski pole build
    Senior Member G-Body's Avatar
    Downers Grove
    Default My ski pole build
    Finally got the time to pull the pics off the camera and resize them.
    Anyway I wanted a ski pole that was removable, tall enough that I could ski around the boat and not decapitate anyone with the rope, and it had to fit completely under the hatch when it wasn`t in use. There was nothing that I liked available on the market so I decided to build one. I ended up with a 5' piece of 1.75" 6061 aluminum for the pole and the brackets to hold it were all made out of some 1", 1.5", 2" and 1/2" black iron pipe. The 2" is used for the ski pole to slide through. If you slice a piece of 2" PVC you can push it into the 2" black iron outer and the inside is 1.75", perfect for the aluminum pole to fit into. The lower mount bolts to the stringers and engine mounts and the upper braces off the heads and the thermostat hole on the intake (I`m not running a t-stat or cooling through that hole). When the pole is removed I put a holder for it on the back of the seat so its always in the boat.
    Anyway heres some pics.
Name:	Lower mount1.jpg
ID:	118163   Click image for larger version.
Name:	Lower in boat 1.jpg
ID:	118164   Click image for larger version.
Name:	Upper mount1.jpg
ID:	118165   Click image for larger version.
Name:	Lower with pole.jpg
ID:	118166   Click image for larger version.
Name:	Upper with pole in.jpg
Name:	Ski pole installed.jpg
    10' Custom with 25 Merc_____17' Sleekcraft jet____85 El Camino SS 5.3L/4l60E 3.73 posi____1980 Chevette 4.3L v6/4l60e____www.fquick.com/G-Body
    Aug 2010
    nice work...
    but geezus man clean your bilge.
    Quote Originally Posted by ka0tyk View Post
    nice work...
    LOL i was thinking the same thing!
    Mine doubles as a drive-in speaker rack at the sandbar.
    Made In The Shade
    Custom Window Tinting
    Senior Member GA Jet's Avatar
    May 2010
    very cool idea. Looks very sturdy too!
    Senior Member crf311's Avatar
    Meraux, LA
    Would love to see the mounting set up for the pole.
    I will take a pic later today for ya....
    Made In The Shade
    Made In The Shade
    Downers Grove
    Yeah the bilge was nasty when I put the ski pole in. The motor that I had just pulled out had puked a bunch of oil out on the last ride. Swapped the motor out, put the pole in, and I cleaned the bilge out after I put the pole in. Looks much better now, too bad I didn`t have enough time to gelcoat the bilge.
