Oil Leaks...
Results 1 to 2 of 2
Oil Leaks...
    Idaho Jet Craig4937's Avatar
    Aug 2009
    Default Oil Leaks...
    I have a olds 455 in a tahiti hull. I took it out Saturday and ran it and found that the distribtor is leaking oil and running down the rear of the motor. i checked and the O-ring looked good and it was sealing when installing the dist.
    Any thoughts? do I need a flat washer between the block and Distributor?
    Sep 2008
    Yuma, Az
    Quote Originally Posted by Craig4937 View Post
    You could make a gasket or use rtv silicone for a good seal.
    boatless....
