How do I put an oil filter on this?
Results 1 to 10 of 10
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Default How do I put an oil filter on this?
    Just realized the D9TE block I am switching to has an oil filter adapter designed for a truck with an oil cooler.
    My old block(D1VE) just had a spin on filter.
    How am I going to put a filter on this thing?
    Am I going to have to put a remote adapter on it?
    If yes, please point me in the right direction(part # maybe).
    Not a clue how to approach this.
    100 years from now, none of this will matter.
    Senior Member Futs's Avatar
    Orange CA, Big River
    Unscrew the cooler adapter and switch it out with the filter adapter.....
    Mar 2010
    Modesto, Ca.
    That made too much sense.
    Ok, I never said I was smart...
    The filter adapter on my D1 block looks pressed in, so I suppose I can buy one that will fit this block?
    Thanks futs.
    Quote Originally Posted by jet460 View Post
    Thanks futs.
    Im not certian, but i dont think its a press fit. Im a chevy guy and chevys are threaded
    El Cajon, Ca.
    It's threaded on both ends... just need to get it out without dinking up the threads... an inside pipe wrench dealy-o works pretty good. If you wish to just get a new one... I believe they are still available from Ford.
    The Bostick®
    chevys have a hex cut in the insert to remove them. Im assuming the fords do to. Look inside and see if you can get a allen wrench in there and get it off.
    Mar 2010
    Modesto, Ca.
    Ok, I'll call Ford in the morning.
    Simple enough...
    058
    058 is offline
    Early ones [68-69 and maybe 70] had a hex, 7/8" or 15/16" I think.
    San Francisco Bay Area
    Cool
    Simple enough...
    Actually, not that simple.
    If you tell most Ford parts counter guys that you want a filter adaptor for the 460, you'll get the male-to-female version just like the one in your D9TE cylinder block. And when you ask for the male-to-male version instead, they'll tell you that there isn't one.
    That's because the male-to-male adaptor wasn't used on the production 460's since 1978 (33 years ago).
    When you walk up to the parts counter, ask for a male-to-male oil filter adaptor for a Mustang 5.0 302 small block. It's exactly the same as the one you're looking for. Which year 5.0 Mustang? I dunno, a late 1980's or later, I suppose.
    LO
    p.s. The OEM adaptors originally had a 1/2-inch round ID. Chances are that you'll get such an adaptor but with a 7/16-inch hex inside in order to facilitate install. I'm not a fan of that smaller dimension but it's just a technicality in the case of most builds. We normally offer a really nice radiussed filter adaptor with a round ID (0.500"+ dia.) and radiussed exit, but we are currently out of stock and don't know when our supplier will have the part again from which we make them.
    High Flow Dynamics
    Mar 2010
    Modesto, Ca.
    Thanks Paul.
    Helpful info, as usual.
