Alternator Bracket
Results 1 to 14 of 27
Alternator Bracket
    Tacoma Wa
    Default Alternator Bracket
    Those of you who are using the 4 point mounting system, how are you mounting your alternator? Right now my boat has a cheesy setup and was looking for something a little nicer to show of my polished alternator. Pics are always welcome. Thanks!
    Lexington, KY
    Here's how I've got mine mounted, probably not what you're looking for. Is this the same cheesy setup that you are currently running?
    Tacoma Wa
    Yup, I've got too much polished metal and chrome on my motor now to have my bracket. LoL Gotta find something trick. Rexmarine has something awesome in their show room but I failed to ask them about it.
    ~Brian
    This one at CP Performance is what I was using. Nice polished aluminum piece.
    500-0957 Alternator adjusting bracket
    Tacoma Wa
    Right on. I am thinking about using some aluminum hex and a couple of heim joints, one with a left hand thread, polish that up and call it a day. I'll post up what I finger out.
    ~Brian
    If you are thinking of doing the adjustable link setup, check out the prefabbed links at March Performance
    You might also make use of cav-plate adjustment pieces.
    The Earth
    Blog Entries
    24
    Quote Originally Posted by LuckyDaze View Post
    ~Brian
    A couple different types, both for Prestolite alternators
    Regular side mount
    Direct drive (must have enough front clearance)
    Tacoma Wa
    Thats bitchin, didn't realize there was a place to get these things fabbed up ahead of time. Always figured I'd have to do it myself. That saves a bunch o time.
    Thanks for those references rex!
    ~Brian
    Hit it where you fit it
    Santee Ca.
    I found this one on Ebay for $25.00 and it is working well with my low motor plate. It is a reproduction of a short water pump style GM mount. It goes in the front of the head with a brace over the #1 exhaust port. It is very sturdy (5/16" thick plate) and has a decent chrome job to boot. It uses a 47" belt when used with a 5" pulley and a standard alternator pulley if you go this route. Good luck.
    Glendale Arizona
    O.K. yeah.........it's filthy. I made this one up about 6 of 7
    years ago. About $8 in hardware store stuff. I know it looks
    like $8 worth. But picture it with a real live shiney turnbuckle.
    Kinda borrowed the concept/idea from March's setups.
    It works though and makes adjustments a snap. I keep telling myself
    that someday I'll buy some real boat hardware, but it hasn't
    failed yet, and with the back seat in you can't see it anyway.
    Never mind the little patch piece with the two screws at the
    top of the alternator. I accidentally broke the little cast ear/bolt
    hole off and had to come up with something, or buy a new
    alternator......... thus the patch piece. Drilled and tapped what
    was left of the ears for a couple 10/32 screws and was back in
    business ($100 richer...or at least not poorer)
    I'm so damned cheap it's scary.
    Tacoma Wa
    Hah, Im right there with ya! Thats almost the same idea I had floating around in my head with what I wanted to do with my boat. Thanks for the imput! And it don't look bad man.
    ~Brian
    Senior Member ironman's Avatar
    Clovis CA
    As posted in the other thread, here is my set up with heim's left and right hand turn buckle style
Name:	75 tahiti after6.jpg
ID:	10082   Click image for larger version.
Name:	alt mnt 4.jpg
    Silverdale, Washington
    I'm bouncing this back up cuz I'm still struggling to find something that I "KNOW" will work. I'd prefer a low mount if at all possible, Don't have room for a direct drive.
    Thanks folks for the advice in advance......john
    Here's the project in question. Any thoughts would be very welcome
    Senior Member forkedup's Avatar
    surprise,az
    couple pics of how i did mine, got the top braket from "the chrome guy" here in phoenix, jrork, that boat is turning out f'n sweet, keep it up
ID:	12543   Click image for larger version.
