I need my at pump Gone threw in okc
Results 1 to 10 of 10
    May 2011
    Edmond, Oklahoma, United States
    Default I need my at pump Gone threw in okc
    Does anyone know where I can get my pump looked at around okc area it spins free but one spot it would cost to much to ship thanks
    Senior Member hotbo's Avatar
    lake Ouachita AR
    whatever happened to LCK Marine in the City?
    Man other than that i really dont know?
    i have a really good Friend that has a body shop outta side of Purcell that has had jets for years and Knows his stuff.
    all my family is from OKC and my wife,i was born there.
    if i can be of any help let me know.
    Travis...
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    May 2011
    Ok I will let you know thanks travis
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    Quote Originally Posted by mikedskustomkraft View Post
    try ron munson of moritz machine in tulsa=he is infomanic on the boards
    May 2011
    i pulled the bowl to see how everything looked i dont really know how bad it is here are some pictures it has a little groove on the shaft that goes in the bowl is that a bad sign and on the impeller its been rubbing on the bowl. and the bowl has some uneven spots is that hurting the performance thanks for your help
ID:	118516   Click image for larger version.
ID:	118517   Click image for larger version.
ID:	118518   Click image for larger version.
ID:	118519   Click image for larger version.
    B1 Racing cs19's Avatar
    Some wear on the tail shaft is ok, a small groove is ok too but nothing major, that area of the shaft is hard chromed so its very tough stuff. The shaft should be measured to check the amount of wear. Your bowl doesn't have a bowl seal so some trash like sand etc. can get in and trash the bowl bushings or hurt the shaft, a seal should be added, simple machining job. The impeller should not be rubbing the bowl, Im assuming its rubbing where the ring on the back of the impeller goes into the bowl? That shouldnt be happening, probably a simple fix.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Quote Originally Posted by justsquirtin View Post
    Thanks,
    I can help you out man. Will you be at the OKC races? If so look me up. I will be in the TAF 339 pits.
    QE 439 Twin Turbo
    May 2011
    Thanks,
    im going to try but im not sure if not are you local i could come to your shop
    New Port Richey, FL
    I'm in Tulsa sir.
    QE 439 Twin Turbo
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    X2...Infomaniac knows his stuff...and can get you fixed up...Correctly!
