Timing problem???
Results 1 to 14 of 22
Timing problem???
    Speed is a function of $$ mightylandwalrus's Avatar
    Jun 2010
    Rio Medina, Texas
    Default Timing problem???
    Hello all. Got a problem and was hoping to get some feedback. Took my boat to the lake this past weekend and noticed the motor running funny. Ran great on the trailer before I took it up there, real responsive, sounded crisp, etc. Got to the lake, dropped it in and fired it up. Sound fine at idol but as soon as you gave it gas it sounded like the timing was off or "misfiring". Though it could have been fuel so I checked float levels and neddle and seats and they were all fine. Also had 7 lbs pressure whole time so it was good there. Got it back to the house. Checked all the spark plugs and they all have fire. Havent changed anything since the last time it was at the lake two weeks ago and it ran great. Any ideas?
    Beer is the answer... but I dont remember the question.
    Sep 2008
    Yuma, Az
    did the distributer move? what modifications to the motor? what is the timing set at?
    boatless....
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    How's the fuel? Did it go bad over time or get water in it?
    Jun 2010
    Rio Medina, Texas
    Quote Originally Posted by YumaJet View Post
    Distributor is set firm. Timing is at 32-33. modifications are pretty standard. MSD 6AL box with MSD high vibration blaster coil and MSD distributor.
    Jun 2010
    Rio Medina, Texas
    Quote Originally Posted by XClutchboy725 View Post
    Fuel is brand new. Could have possibly got water in it but highly unlikely. I have a fuel seperator and I clean it out regularly
    Quote Originally Posted by mightylandwalrus View Post
    What kind of scoop do you have, fiberglass?
    Take a look inside you might be surprised
    Jun 2010
    Rio Medina, Texas
    Basset polished aluminum scoop + flame arrestors. While I was messing with the carbs I took it off and adjusted them on the lake, ran without it and it did the same thing. Why?
    Sep 2008
    Yuma, Az
    what kind of cam, pistons, rods, heads, springs, rocker arms? hows the oil?
    if you eliminated the fuel system, carb, ignition, plugs & wires, it might be inside the motor.
    did it make a popping sounds at higher rpm's? flat cam if its hydraulic will make that sound.
    boatless....
    Jun 2010
    Rio Medina, Texas
    Just bought the boat about 3 months ago and havent had the motor out yet. I do know its a solid roller cam though I dont know the size. Oil looks fine smells fine.
    Didnt make it at WO in fact it was very responsive and sounded crisp. It was in mid range say 2500 to 3500 just cruising the boat. Could it be the springs in the distributor?
    Feb 2011
    Wash.
    What was the temp. last time you ran & the temp ran this time? Could it be the 10* Eth. in the fuel. Summer Blend.It could be .
    Jun 2010
    Rio Medina, Texas
    Quote Originally Posted by getrdone View Post
    Roughly same temp both times I was out. 90 - 100. I only run 93 octane pump gas nothing else
    Sep 2008
    Yuma, Az
    it never hurts to open up the cap and see if anything burnt up. mine was burnt and it still ran hard & then i replaced the parts and it ran just as good.
    boatless....
    Orlando.FL
    Sounds as if something in the valve train isn't right pull valve covers and check the rockersa and valve lift,etc.
    Jun 2010
    Rio Medina, Texas
    Quote Originally Posted by Schiada 201 View Post
    ran valves and checked springs, lifters, etc. all check out normal
