Bbc rpm / timing question
Results 1 to 3 of 3
    Mar 2011
    Default Bbc rpm / timing question
    I have a BBC gen 5. ALL STOCK. Anyone know what kind of rpm I should be getting? Also anyone do a little testing with timing on these motors? Any help would be great. I am running at 4900 rpm and the timing is at 34.
    Senior Member bc18's Avatar
    Quote Originally Posted by CROCKETT22 View Post
    Running same timing at 4500 rpm. What carb set up do u have I'm running 2 Holley 650's weiand tunnel ram and berkley bc impeller gps at 78.3 mph. What set up at mph u running at 4900 rpm?
    Actual HP (estimated) altitude of operation , Impeller cut , pump health as well as an accurate Tach all come into play here , maybe fill in the blanks ? Tom
    BTW FWIW if your at sea level with an accurate tach , an A impeller, a good working jet and around 450 HP your numbers are pretty close
