Oil Change!!!
Results 1 to 9 of 9
Oil Change!!!
    Idaho Jet Craig4937's Avatar
    Aug 2009
    Default Oil Change!!!
    I have an olds 455 in a jet boat and I can't figure out how to drain the oil out of it! i do have a oil sucker that usually fits down the dipstick tube, but the smallest tube doesn't fit down it.
    the oil pan drain is under the engine.
    so any ideas?
    Craig
    Sep 2008
    Yuma, Az
    take the engine out and drain the oil and change the filter.
    boatless....
    Jul 2010
    Lubbock, TX
    Quote Originally Posted by Craig4937 View Post
    so any ideas?
    Craig
    You *could* take the dipstick off and put the tube directly into the pan.
    Once drained (assuming you can get to the drain plug) put a hose with a threaded plug on it.
    "No, my boat doesn't need any more power" - No one ever
    Lake Havasu az.
    Quote Originally Posted by FormulaZR View Post
    That does work...just make sure you disconect the battery first.....
    That doesn't have a car pan does it?
    Sheriff Joe Arpaio
    Jul 2010
    Lubbock, TX
    I can't remember, but can you put the tube down the oil fill at the front of the engine?
    Orlando.FL
    Unscrew the oil filter put a pan under and roll over the engine and pump it out. I take the plugs out to relieve the compression, takes only a couple of minutes. I have a remote so I only have to use the out line.
    Aug 2009
    Aloready tried that, you can't get down to the bottom of the oil pan...
    Aug 2009
    Quote Originally Posted by Schiada 201 View Post
    This is a good idea! But it won't hurt the motor turning it over wouhout any oil in it?
    Lake Havasu az.
    I just checked mine....with the dipstick tube pulled out of the block there is a 3/8 i.d. hole that a suck pump will fit down......pumping the oil out with the oil pump won't pump all the oil out...pickup could be 1/4-1/2 off the bottom of the pan.....and no....cranking over with no oil pressure or spark plugs PROBABLY won't hurt anything....but it is an olds
    Or you could get a replace plug for drain plug all set up for a hose deal......
    pile a gang of rags under the pan and hot swap them out. My olds would siphon 8qts in about 40 min with a 3/8 id drain hose....I did use a piece
    of clear hose so i could see where the oil was when i started the siphon
    Sheriff Joe Arpaio
