Water pressure / Plumbing issues 20 psi +
Results 1 to 14 of 26
    Unhappy Water pressure / Plumbing issues 20 psi +
    I need some help with my jet boat w/ ford 460 berkeley jet. it is still building too much water pressure at 3,000 rpm after install pressure relief valve. It builds 20 psi plus even with the valve all the way open. I used -8 stainless hose through out the whole system. Off the pump I have a tee installed with the pressure relief valve then from there goes to the front to another tee then goes into front cover. Off the intake manifold one port goes to another tee then dumps out of the transom exhaust. the other port on the intake manifold goes to the water injection on the headers. ??? I don't know what to do ???
    Feb 2009
    MANTECA
    Default pressure
    Put a gate valve in front of the pressure relief valve, then you will cut down the volume of water going to the relief valve.
    B1 Racing cs19's Avatar
    Put a guage on the block and see what pressures your getting.
    A regulator will solve the problem. They do make them for industrial use and work great on boats, look for somethng that can take some good pressure, like 375-400 to be on the safe side, the more power you have the more pressure you are likley to make. Cars and trucks run at around 15 psi. from what Im told (not a car mechanic)
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    cs19 how much pressure you run at WOT? I know that a car is suppose to run at some low PSI but i was told that since we run a open system that we want more pressure to helo push out steam pockets. Ive been running mine at 25 PSI for a few years now.
    Salem,Or
    Are you sure water is coming out your water dump that comes off you relief valve????
    the way my 460 in my tahiti was plumbed
    pump to gate valve
    gate valve to the T that had the relief valve on top with water dump
    from front of T to the water pump cover
    water pump cover to thermostat housingr
    then one hose off each side of thermostat housing to exhaust manifolds
    With Spray there is a way!!!
    Jul 2009
    Here is a great way to do it, but you might want to call him, and see what he has available. His kit works great.
    Performance Jet -Jet Boat High Performance Design
    25-30. Never had any issues
    Santa Clarita
    Same here
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by KONABOY71 View Post
    20-30 psi is fine. I think your just being paranoid. Most stock jet boats dont run a bypass or a presure regulator. If your not blowing out the intake manifold gaskets or head gaskets...just run it. A closed system runs at about 12-16 psi before it pops the cap.
    higher HP levels require a regulator or a bypass because of the inceased water volume thru the pump at higher rpm's.
    One question though? why are you runing a T in your dump line? I understand the T before the water injection before the headers, but not on the dump line. I run a -10 in off my reg to a T that goes to 2 -8's into the front and a sinle -10 to the dump. I run my headers dry.
    Also, if your running the regulator all the way open its not doing anything. You need to close it down before it will work properly. I dialed mine in with air pressure and it was off by 2 psi when i checked it with a gauge on my manifold running it at the river. You cant set it with the hose!!!!!
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    your bypass line (one going overboard)needs to be larger then the other lines
    Quote Originally Posted by Fonz69 View Post
    Why?
    He has a -8 T'd to probably 2 -6 lines to the headers and then a -8 dump line. That "should" be plenty. 2-8's are larger than 1 -10, no? Also he says its above 3000 rpm's and the header Spring and ball should be open if its working right. Now if the problem was at idle or just off idle then i would agree with you somewhat. If your running a single -8 inlet and only running "ONE" dump line the same size it could create this problem.
    Dont know if he is using the ball and spring T though. if i has a busted spring or is hung up it could cause so issues, but he didnt say if water was coming out the headers or not either....
    Glendale Arizona
    Agreed. I ran mine straight through with all -8 line and fittings and a wide open gate valve for years without issue.
    thousands of other people do too, works fine for alot of people, Its when they get into more HP they get issues. You can build some serious pressure with a big motor and good jet-drive.
    I hope I'm being just paranoid. This is my first jet boat let alone my first time building one, so I just learnas I go. I've gotten alot of information through this site. It's just that I spent ALOT on the engine. It's a ford 557 about 700 hp. So I'm pushing alot of power to the jet and just thought 20 psi plus would cause mechanical failure and possible blown gasket or water in the oil or hydrolock. at 5400 rpm its about 30 psi at idle its about 5psi. heres a sketch of my setup
