stripped intake holes
Results 1 to 14 of 18
    May 2011
    Edmond, Oklahoma, United States
    Default stripped intake holes
    i need to find out how i can fix these holes for my shoe the previous owner drilled the holes crooked and went all the way through i tried marine tex but im not happy with that can a machine shop fill and re drill the holes thanks for your help
ID:	119229   Click image for larger version.
    Dallas, TX
    A machine shop could probably use time-certs to fix them. They have a thread insert that is bigger than normal to repair previously repaired threads.
    http://www.timesert.com/html/bigsert.html
    May 2011
    those are what i wanted to use but the picture doesnt really show how bad it is i think i would havw to drill 1/2'' hole to get em straight again
    Dallas, TX
    Quote Originally Posted by mikedskustomkraft View Post
    That is where the machine shop comes in. They will have the equipment to square it up and drill as small a hole as possible to make the repair. Those big-certs from Time-cert are made to fix a hole that has already been repaired with a coil type insert. They are going to be pretty large.
    Good luck with what ever you do. I'm sure it can be fixed fairly easily by a good machine shop.
    May 2011
    ok i will find a machine shop tomarrow thanks for your help
    Anaheim Hills
    Couldn't the holes be welded closed then re-drilled and tapped?
    X's 2 ,Weld them closed and re-drill/tap them , cheap, simple and a good repair you can be comfortable with Tom
    May 2011
    Ok well I took the intake to 3 different welders and they said they can't do it so I am going to try timeserts/ heli coils
    Anaheim Hills
    I'm just curious... Why did they said it couldn't be done?
    May 2011
    They said they wouldn't be able to get the aluminum hot enough to get any penatration I even told Em to open the holes and fill it back up they were probably scared of messing it up
    May 2011
    They said they wouldn't be able to get the aluminum hot enough to get any penatration I even told Em to open the holes and fill it back up they were probably scared of messing it up. I didn't mean to post twice
    Member hollbrow's Avatar
    South Ga.
    Default You just ain't...
    Found the right welder yet.
    Default intake
    ship it to me and i will tig the holes closed for free, one day turn-a-round , you pay the freight.
    May 2011
    Quote Originally Posted by johnray069 View Post
    Johnray that's very nice of you . Where will it be shipping to ? And Do you know the problem the other 3 guys were talking about ?
