Cable Issue!!
Results 1 to 9 of 9
Cable Issue!!
    Southwest corner AR
    Default Cable Issue!!
    I had this happen this weekend and it is a defect not a broken cable! The way it looks to me is that the crimp on the 1/4" rod end wasn't done properly causing the 1/8" SS cable to slide out of the 1/4" rod! There isn't any of the 1/8" cable inside the rod part of the cable Is this common or has the quality gone to crap?
    [IMG][/IMG]
    WT
    WFL Crew!!!
    Jul 2010
    Lubbock, TX
    I just had to replace my diverter cable due to the same issue.
    EDIT: My cable was at least 3 years old, but it broke in the same place as yours. Almost like the crimp just gave up...
    "No, my boat doesn't need any more power" - No one ever
    Southwest corner AR
    Quote Originally Posted by FormulaZR View Post
    This cable is one season old! The others that I have had never broke like this always on the 1/8" cable part! (A kink break) I think I have heard about others doing the same thing!
    WT
    WFL Crew!!!
    well good i'm not the only one that broke a diverter cable that was less than a season old last weekend.
    corona calif
    Default Cable
    Quote Originally Posted by sandeggo View Post
    Who's make of cable is it?
    I hit my throttle in reverse and my handle went up fast and snapped mine in the same spot. Less than one year old....
    Made In The Shade
    Custom Window Tinting
    Probably a good idea to double check that the limitation of the actual cable throw itself (determined by the crimps in the cable sheathing and body on either end ) aren't or don't become the terminal "stops" for the action or "throw" of the device itself. In other words for example if the trim actuator arm or bucket arm will travel further than the cables capability the leverage could concievably push the sheath or crimps out? I'll expiriment with one later and post pics , We have seen a couple of these in the hundreds of cables we have sold over the past couple seasons on trim but not Fwd/Rev .Tom
    Southwest corner AR
    Telflex!
    Mine didn't snap! It pulled out of the crimp! Not crimped well!
    Tom, this was a Place Diverter cable!
    WT
    WFL Crew!!!
    Kingman/Golden Vly, Az
    just put the 1/8" cable back into the 1/4" rod & "properly" crimp it & your good to go ...just sayin' my .02 cents FastRat
