Something popped in my pump today
Results 1 to 8 of 8
    renegade1
    Jul 2009
    Missouri
    Default Something popped in my pump today
    I had the boat in reverse today, and when I hit the throttle I heard a pop. When I put it in forward, It was fine at idle. I hit the gas and the engine just reves. I took it to the dock at a little over idle without problems. What do you guys think it is, a seal or something? Dosent make any bad nosies, just wont hook up. It is a 2002 Legend pump in a 21 ft bowrider. PLEASE HELP.
    Shell Knob, MO
    Were you in shallow water? Reverse may have churned something up and got into the pump. Take a light and look in at the inmnpeller and look for any debris.
    Duane HTP
    renegade1
    Jul 2009
    Missouri
    I was is shallow water, I glanced in there, but not real hard. Ill look better sometime this week. I just parked it, were I store it. I had the Day from Hell, just wanted to get home. I am in Mo. too. I bought a couple parts from you last year. Still new too the jet pump world. Somebody else told me it could be a wear ring or a bad impeller. Do you know how to tell if they are bad?
    I went up to the end of Grant line in the delta yesterday, and when I started up and gunned it it revved way up and wouldn't go.......a 1/2 inch stick was wedged in the impeller....luckily it's a JE pump, so I was able to clean it out and go.
    Shell Knob, MO
    Quote Originally Posted by renegade 1 View Post
    Possible I suppose, but a bad wear ring usually lets the pump slip bad out of the hole and impellers usually would not cause a vibration unless you had a chunk knocked out of a blade. Look in the pump very closely. Had a boat we were testing last week do that and is was a little forked stick about 1" long caught on one of the blades. Took a big long screw driver and knocked it out and problem was solved. It doesn't take much in there to cause a problem like that.
    Duane HTP
    Mar 2010
    Clarksville, TN
    Sounds like you picked up a stick They won't go anywhere if it has 1 in it but will idle ok
    Jul 2010
    Lubbock, TX
    I got some reeds tangled on my loader, and it did EXACTLY what you're describing. Sounds like you've got something between the mouth and the impeller.
    "No, my boat doesn't need any more power" - No one ever
    renegade1
    Jul 2009
    Missouri
    Default Fixed
    Sticks in the intake, just like you guys said. Thanks a bunch for the help.
