Jet pump Ratchet
Results 1 to 14 of 14
Jet pump Ratchet
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default Jet pump Ratchet
    Show pic's of you ratchet installations here. How do they operate.THANKS I will need one soon
    Anaheim Hills
    Quote Originally Posted by swtd View Post
    You mean jet-a-way?
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    I am starting to realize that the jetaway i installed this year is going to be the single best addition to the whole boat. you will either have to pull the motor or the pump to install the unit. You will probably get away without moving the motor if you have the boat in your avatar. I had a SWTD, and the driveshaft was over a foot long. your problem will be reaching back there in the pod to engage/disengage it. All you have to do is remove the bearing cover, double drill the thrust bearing housing, set your tolerances for the bearing, and make sure you put some type of sealant between the shaft, and the collar the seal rides on, i had a heck of a leack, bypassing the seal between this sleeve and the shaft, had to remove the pump, disassemble the unit, apply bearing and sleeve loctite to the shaft, then re-assemble, other than that it was painless. It took me longet to relocate my motor (in my TX19) than it did to install the jetaway. i am sure it would have been easier with a rail kit though.
    Sep 2008
    beaumont ca
    Default yes get-a-way
    Yes my driveshaft total is like 12 inches including u-joint. motor placment from back of valve cover to rear bulkhead is 5 1/4
    Senior Member CP598's Avatar
    Sep 2008
    Not the best pictures.
    Senior Member Futs's Avatar
    Orange CA, Big River
    You need to flip the seal the opposite direction behind the shaft bearing or it will leak bad.
    Sep 2008
    beaumont ca
    Default Thanks
    Quote Originally Posted by CP598 View Post
    Really nice equiptment you got there!!!
    Glendale Arizona
    Here are a couple. I later found out I could've slid the motor back another 1/4". Apparently the snapring on the pump shaft can/should meet the front of the jetaway. Once everything is set and positioned the snapring can be removed prior to final assembly. No big though. I've been running mine like it is in the photos for 3 years. I just cheated myself out of a 1/4".
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    If you can drill and tap the holes straight without pulling the housing your the man, I tried it on my SWTD, upside down...long story short, pulled the housing had to have a few holes welded up and start over...LOL
    B1 Racing cs19's Avatar
    Highly advise that you dont try that, unless you do this stuff everyday thats a tough thing to do. A drill guide is your friend if your gonna try that
    Southwest corner AR
    X 2 I used a 1/4" drive socket that would fit the bore of the jet-a-way and ran the drill through the socket bore! It works good for a guide and cheap! 2 would even work better!
    WT
    WFL Crew!!!
    Led
    Led is offline
    Jul 2010
    I was only the "make it happen" horse and got in a hurry and screwed it up.....lesson learned.
    Southwest corner AR
    Led, you are not the first and surely won't be the last!
    WT
    WFL Crew!!!
    Senior Member sdpm's Avatar
    Your bolts look a little short that are holding your grate. You might want to take alook at them. Also no ubolts around caps on ujoint.
