[Question] CS 19 or clockstart
Results 1 to 9 of 9
CS 19 or clockstart
    Green Bay Wi,USA
    Default CS 19 or clockstart
    Impeller sizes. Can one of you guys explain, in general, larger impeller sizes. I have heard of AA, 3A and 4A. Diameters of 9, 9 and 1/4,9 and 1/2 inches. Do these relate to the AA,3A and 4A? I am hoping to put more power to the pump soon. Hoping to dyno in 2 weeks. Where do high helix impellers fit into the mix? Thanks, DEL.
    B1 Racing cs19's Avatar
    Del, there are impellers available up to 5A from AMT. The 5A will need a bowl modification because its so large, the 4A and below do not. You will be limited to what size impeller you can run if your running the smaller suction housing and bowl which only has a bowl register of 9.125, you cant run anything bigger than basically a "AA" with that housing and bowl, in order to the run the larger impellers you will need the more modern suction housing with the larger bowl register and a newer larger bowl. Your other option is to run the adapter ring which is basically a piece of welding rod and it will allow you to run the larger impellers while still using the smaller suction, you would need to bore the bowl ID to accept those parts and so it would fit onto the adapter piece (welding rod) as well.
    The high helix offers the same sizes but you will find them harder to turn in the larger cuts. A non hi helix AA thats done right in a good working boat that is loaded properly will require some substantial HP to turn it up to 7000.
    Hope that helps a little.
    Chris
    Green Bay Wi,USA
    Thanks Chris. I will call or pm after Dyno.
    Members only MAXIMUS's Avatar
    Close by
    Chris
    Chris what hp does it take to spin a hopped up panther pump to 7k?
    Panther and 7000 rpm don't belong in the same sentence lol. Scary thought!
    Chris
    1000hp? More?
    Senior Member bp298's Avatar
    LHC
    1000hp? More?
    way more.
    Sep 2010
    would 1200hp do it?
    Q.C./Big River
    Not to thread jack but i have been wondering this myself. I am running a B/C stainless right now turning it to 7200. What would I expect out of a AA or a Hi Helix A? Would it hurt the top end? How much hole shot or et would I gain?
