is this a decent Cam
    Senior Member slotracer's Avatar
    Default is this a decent Cam
    thinking about buying this cam, is it a decent cam? basic stock 460.
    http://www.performanceboats.com/part...chain-set.html
    slot
    87 eliminator
    next boat ??????????????
    new owner of the redneck yacht club
    Stockton, ca.
    Senior Member 79sleek's Avatar
    May 2011
    Wyoming
    Default i think
    Quote Originally Posted by slotracer View Post
    thinking about buying this cam, is it a decent cam? basic stock 460.http://www.performanceboats.com/part...chain-set.html
    Sounds like good deal its a little small but should help a bunch on a mild 460 the cam I'm running is like 1 or 2 sizes bigger really woke the ford up hope some others will chime in good price id get it you can always change to a bigger cam later if you don't like it what impellor are you running try to mach your cam to your impellor to see great gains I've got an a in mine it gained a lot with the swap
    San Francisco Bay Area
    Cool
    That would depend on the application. For a jet boat? It is bigger than the OEM 429/460 passenger camshafts but has less duration than the OEM 460 Marine engine camshaft, for example. I'm using something very similar for my F250 towing engine.
    The timing chain does not appear to be a double-roller but a traditional OEM link-pin style.
    LO
    High Flow Dynamics
    Senior Member wolfie's Avatar
    Comp Cams and Clay Smith both have cams with profiles designed for jet boats. I went with a comp cams in my BBC.
    COMP Cams: Xtreme Marine™
