Question pump gaskets
Results 1 to 3 of 3
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default Question pump gaskets
    What creates pump gasket blow out. Had it happen several years ago Twice. I Will be installing a full stud kit soon. Hope that helps
    Owner/Crew Chief 1/4 Miler's Avatar
    Rural Missouri
    We don't use a bowl gasket. Our bowl is set up for an 'O' Ring with 8 aircraft grade studs ..... Works great and we typically build a lot of pressure in our pump, a lot more than most.
    machine a register, for the Dominator style o-ring, on the bowl.
