CJT Commander problem with dominator jet
Results 1 to 5 of 5
    Jun 2011
    Default CJT Commander problem with dominator jet
    I have a 96 commander with some problems, When i took my boat out it was running fine, then it started to vibrate real bad. I was able to idle back to the dock while i was going back i would give it gas and i would not go any faster then idle but vibrate real bad. What could be the problem?
    Quote Originally Posted by CJTCommander View Post
    Inspect the jet thru the cleanout (if out of the water) or roll under it and look into the intake , likley is you injested something into the jet , rock, stick, trash bag , ball cap etc , call or PM if you need more help Tom
    Jun 2011
    I took my bowl off and my grate nothing to be found inside, could there be a chance that a bearing is going out?
    Oct 2010
    Lake Dallas TX
    still have the key in the impeller?
    Jun 2011
    Quote Originally Posted by hellnback View Post
    Yes, everthing is checking out ok
