Throttle cable size, 33series/43 series?
Results 1 to 3 of 3
    Las Vegas, Nv
    Default Throttle cable size, 33series/43 series?
    What size cable are You guys using for the type of set up in this picture? I am trying to get my linkage set up. I have mine set up to the bell crank mounted on the intake ,but am having trouble getting it to opperate smoothly and am considering changing to the side set up like in the picture.
    When I press the trottle pedal to WOT the cable or linkage or something causes it to bind and stick.
    I just want a simple setup but nice and clean also. The cale in the picture looks to be bigger than a 33 series but it may just be the picture......H
    All the throttle pedals and cable clamps I have ever seen were designed for the 33 series cables.
    Aug 2010
    33 series from cpperformance here... along with clamp and pivot/release.
    nice and smooth.
