Help find EASY Part
Results 1 to 10 of 10
Help find EASY Part
    Member BuddaMan's Avatar
    May 2011
    Inland Empire
    Default Help find EASY Part
    Hey guys, Need some help here, when I first bought my boat it didnt have a lot of parts, slowly me and the wife and fixing what needed to be fixed the first time but wasn't(dumass org. owner) Ive been told there is a spacer or block that goes here that im missing. My guy said it will help with sime of my steering binding/resistance since the nuts dont allow for movement. I cannot for the life of me find a billit spacer or adapter that goes here" can you guys send me a link of what parts you know of or bought that will fix my issue, Thanks so muchClick image for larger version.
    Sep 2009
    Red Mountain, Az
    Call GS marine in Corona...they will fix you up
    not ****** little squirt's Avatar
    Waikiki, HI
    Here ya go, call em up ask if they have the spacer kit separately
    Jet Boat Performance, Steering Extentions and Swivels
    not banned
    May 2011
    Inland Empire
    Thanks guys, What did Berkeley use in the first place? same kind of 2inch spacer? Wondering why cant I find it on berkeleys website
    Cas
    Cas is offline
    Angry American Cas's Avatar
    How long of a piece do you need? 1-1/4" maybe? I make my own out of stainless steel tubing....I can cut you a piece and send it off for the few dollars of shipping.
    Here's a pic of what mine looks like-
    Cas
    Cas is offline
    btw, if you loosen the bolt about an 1/8th of a turn and then tighten the bottom nut on the top side against the arm, it will free it up so there won't be any binding.
    Quote Originally Posted by little squirt View Post
    We do indeed have the Billet extensions in 3 standard lengths and Custom lengths as well as several types of swivels as well as spacers and stainless studs to make this a very clean transition and connection Tom
    May 2011
    Inland Empire
    Ok thans soo much, Do I just measure the legenth of it now? I for sure want one, Ill measure it and let you know for your opinion
    Cas
    Cas is offline
    It's best to take it all apart, hold the steering cable up so it's coming out straight and then measure the distance from the bottom of the steering to the top of the steering arm. In looking at the picture you posted, it looks like the steering cable can go up a bit so it's not touching the bottom of the tube where it comes through the transom adapter.
    May 2011
    Inland Empire
    Yes its 1-1/4" long, Can you please make me one and how do I pay for the shipping?
