Bilge pump choice..
Results 1 to 14 of 14
Bilge pump choice..
    Jun 2011
    Dallas Tx
    Default Bilge pump choice..
    Im about to order a automatic float bilge pump for my boat to replace the old one. After looking theres so many choice i got lost. Any suggestions on brand and GPH? I had my eye on RULE 500GPH automatic switch.
    Senior Member motomattox's Avatar
    Apr 2011
    It's not an automatic set up, but I just picked a 500gph bilge pump for $17.00 from Walmart. Couldn't beat the price. It's a 'Tsunami' by Atwood, and you can replace the motor with drop in cartridges for even less money if you ever need to. Just a thought for you....
    "Keep talking...it aint often I get to hear a genius speak"
    in the works MAD GREEK's Avatar
    Jan 2010
    Corona, CA
    make any bilge pump and automatic..
    Mayfair Automatic Float Switch - Dana Marine Products
    TEAM CUPCAKE RACING
    Ladera Ranch
    That switch is a poor design. Mine failed at a bad time and I hadn't wired it to operate on the switch also(my bad).
    I went with a sahara, I think its 1250gph. Internal switch. Works very good. I keep my old mayfair 1000gph with aligator clips in the boat just in case.
    Massachusetts
    Rule 4,000 GPH with a float switch. I mounted it all to a piece of cutting board so no holes to drill in boat. If you spear a wave or spring a leak, 1,000 GPH pumps will not save your boat. I also have the original 1,000 GPH pump to pump out light stuff.
    Real Boats Don't Have Propellers!
    -- Rivernut
    whats a goodtime cost? Nixonnow's Avatar
    Feb 2011
    Fort Mohave, Arizona
    i am also lookng at getting a new bilge pump. actually was looking at the automatic ones as well. i have a rule 500 gph on switch on my dash. was thinking about an upgrade to a 750 gph as well. would an automatic pump wire up the same with the existing wires?
    and rivernut that is one of hell of a discharge line.
    The Earth
    Blog Entries
    24
    The Attwood Sahara's are good little pumps (500, 750, 1000 gph), we have never had a return on one that I remember. If you have the room I'd run the 2200 though as said above 1000gph won't save your boat in a serious incoming water situation. Link
    Then I'd use the Water Witch electronic switch and wire it so you can switch back and forth between manual operation or let the Water Witch control it. Link You can use the Water Witch on any pump, not just the large ones. I prefer the electronic switches over the float style. I have used them both in the past.
    Massachusetts
    Do an Internet search about ADVERTISED flow rates, head height and voltage of bilge pumps. Many pump only 1/3 of their "rated" amount. They sometimes rate them at zero height or no hose or at an unrealistic voltage like 13.6-14.3 volts. I fish bass tournaments on Lake Champlain where 6-8' waves are common and facing a 60 mile run to get back may involve many total swampings from large waves. Many boats run two large pumps. Some separate and some run them in series in case the first one fails. Boats over 20' are not required by the Coast Guard to have floatation. When the boat floods it sits lower in the water, and the egine will hydrolock if the intake is at the waterline. The longer it takes to pump out the water the more waves come crashing in putting you back to square one. That hose I put on the 4,000 pump came from a custom hose shop. Rather than drilling a 2" hole or reducing it down and cutting it's volume in half, I opted to run it out an existing rod holder tube on the hatch lid / deck. The holder is only occasionally used when striper fishing and certainly isn't used when running rough water. It pumps the boat out quickly. Water above the driveline, even one time can ruin a jet pump thrust bearing.
    -- Rivernut
    Jun 2011
    Dallas Tx
    A 1000 - 2000 would be good but my hole in the hull is only a 1/2'' while the hose is a 3/4''. So upgrading to that much Gph would require me to add another hole or to make my current one larger?
    Jun 2011
    Dallas Tx
    Default Pics
    Pic of the 1/2 size bilge exit hole on the exterior of the hull and one of the 3/4 hose coming from the bilge. The hole above the old through transom exaust with the penny above it is plugged. The one to the right is the exit for the plumbing. Planning on buying two new bilge pumps and removing the old one.
Name:	Side Bilge  6-4-11.jpg
ID:	121989   Click image for larger version.
Name:	Unused Bilge 7-4-11.jpg
ID:	121990   Click image for larger version.
Name:	Bilge hull 7-4-11.jpg
    Jun 2011
    Dallas Tx
    Quote Originally Posted by ItsJohny View Post
    3/4 hose plugged.
Name:	Unused bilge hull 7-4-11.jpg
    Sep 2008
    Yuma, Az
    Quote Originally Posted by Nixonnow View Post
    on my daytona, i wired both up to the same switch and also connected the hot to the starter solonoid. it worked good because if i needed to force water out, i could do it with the switch. and both would turn on when the automatic pump would turn on, so that switch was never used. after having a lot of water in my bilge this weekend, i wil definately buy a automatic bilge pump this week!!
    a 500gph pump is good enough. if you have a hole or your intake somehow falls apart, AINT nothing gonna save u..lol
    boatless....
    Jun 2011
    Dallas Tx
    I imagine a 4000 gph would work pretty well lol.. I found a sahara 1100 gph, think im going to order two of those and a manuel / automatic switch.. One of the problems i had this weekend was getting water on the outside of my stringers. I think my injectors in my headers are leaking some where
    X's 2 on the Sahara , something you don't want to "Skimp" on Tom
