Oil Leak issues....
Results 1 to 14 of 17
Oil Leak issues....
    Idaho Jet Craig4937's Avatar
    Aug 2009
    Default Oil Leak issues....
    I'm still having oil leak issues on my Olds 455 around the Distributor. It does have a o-ring seal and a gasket around the top of the dist.
    any Ideas?
    I hate oil leaks !
    Craig
    Aug 2009
    Default oil leaks
    Any ideas? can't believe nobody has this before.....................
    Craig
    Cas
    Cas is offline
    Angry American Cas's Avatar
    have you tried using a thicker gasket or stacking a couple of them up?
    Quote Originally Posted by Craig4937 View Post
    any Ideas?
    I hate oil leaks !
    Craig
    Craig , the original and after market Olds distributors , were designed to use and oring so if that oring or the area on the intake is not clean or damaged , in typical Olds fashion oil will blow out the path of least resistance if a little blow by is existant, you could fashion a gasket to use under the Distributor flange as well but bear in mind that gasket will act as a "shim" and begin to change the engagment of the Distributor gear to cam . If you find that the o'ring looks good you may want to consider how and how well or if the crankcase is vented.... Tom
    Aug 2009
    Tom, that is a concern. If I take my finger and feel the back of the distributor hole in the block, I can feel ridges on the rear of the hole but not up front. I don't want to take something like sandpaper and try to smooth it out and risk dropping some bits into the engine. I am going to try to get a bigger o-ring....
    Craig
    Senior Member pilot940's Avatar
    Chandler, AZ
    Try putting a super thin layer of silicone on the bottom edge of the dist, let it dry then grease it a tad and install it.
    Could the leak be coming from the intake manifold to block seal?
    seattle
    are you sure it is coming from the distributor. it could be your intake??? the rubber seals that they give you like to squeeze out alowing oil to come out and rest around your distributor. happened to me. just pulled out the seal, cleaned up the gap with paint thinner, and sealed it with silicone. come to find out alot of builders don't use the gasket. they silicone it from the start........
    Chandler, AZ
    Quote Originally Posted by 1975sleekcraft View Post
    This happened to me as well, except I didn't use the seals and there wasn't quite enough silicone between the manifold and the block.
    Aug 2009
    Quote Originally Posted by pilot940 View Post
    First of all, Thanks for all the info. I didn't use the gaskets, I used RTV. My question is, do you have to take the intake off or can you seal it it from the rear with the distributor out?
    Craig
    Ladera Ranch
    Craig
    Do it right, pull the manifold and clean all surfaces well. I like the gray RTV.
    Ladera Ranch
    Oh, and don't use the turkey tray gasket. Get the paper gaskets.
    Aug 2009
    Yes, I did get the paper gaskets. no turkey tray here......
    and yes I'll do it right......
    Craig
    Aug 2009
    Default oil leak
    Ok, we are going out tonight to see if we have it fixed. I used a little bit bigger o-ring and I sealed the intake to block mating surfaces. It did look like it was sealed between the block and the intake in the rear.....
    Craig
    seattle
    this is interesting...i was told by people on PB that the turkey tray was the way to go. one reason was it keeps your intake cooler( what i was told) i have been using one for 9 seasons now without a problem. there is nothing wrong with sealing up the front or rear of your intake(oil seal) without removing your intake. it is all about how you prep. sounds like you have got her licked.........
