63 @ 5,300 at sea level, would u complain?
Results 1 to 14 of 14
    Apr 2010
    Default 63 @ 5,300 at sea level, would u complain?
    buddy just bought a real nice 18ft jet
    he doesn't think its fast enough.
    i'm not saying what brand for anonymity, but its clean and blueprinted
    motor is a 468 BBC with a solid-lifter cam twin holly dbl pmprs and a tunnel ram and basetts.
    dominator pump with ride plate, droop and place div. i don't know what shoe or impeller so don't ask, neither does he.
    hits 5300 at 63 mph at real close to sea level on a hot day...
    he thinks it should be closer to the 6k rev limiter, 53 hundo sounded like a lot for big cube motor...
    i know the bone-stock southwind hits high 50s at 4500ish with a bbf
    987 is offline
    SWDBA 987's Avatar
    Aug 2010
    Rio Rancho, NM
    I could be wrong but FWIW that doesn't sound right. My first jet was a Hornet 19', no bottom work, no shoe, no ride plate, had a loader and diverter (stock berk pump), fairly heavy boat, old tired 454 short block, edelbrock aluminum heads and mild cam, air gap intake, 750cfm carb.....nothing special.........I hit 62 @4800RPM, heres the kicker....Altitude 5000 feet!!!!
    With his engine at sea level and in a 18', seems like he should be going faster...
    96' 18ft Pantera Drag Boat
    Apr 2010
    Quote Originally Posted by 987 View Post
    Right!?
    how do the impeller letters match up? whats the diff bet. a, b aa, yadayada?
    Just to help out here What boat (hull) ,as it (the secrecy) makes a huge difference in the equasion?
    the padawan
    Jul 2010
    Anaheim
    i second jetboat.... hell we could be talking about a mini day.... and they make a difference, every single one makes a difference.
    Apr 2010
    ok, lets just say its not a day cruiser or mini-day, but you knew that b/c its 18 feet, but its also not a tahiti or hawaiian
    Sep 2008
    OC, CA
    Ok, I'll play. If its a tight pump spinning an A at about 500 hp in say an 18 gullwing, you should be hitting 80mph.
    Senior Member 79sleek's Avatar
    May 2011
    Wyoming
    Default sell it
    Quote Originally Posted by southwind74 View Post
    buddy just bought a real nice 18ft jethe doesn't think its fast enough.i'm not saying what brand for anonymity, but its clean and blueprintedmotor is a 468 BBC with a solid-lifter cam twin holly dbl pmprs and a tunnel ram and basetts.dominator pump with ride plate, droop and place div. i don't know what shoe or impeller so don't ask, neither does he.hits 5300 at 63 mph at real close to sea level on a hot day...he thinks it should be closer to the 6k rev limiter, 53 hundo sounded like a lot for big cube motor...i know the bone-stock southwind hits high 50s at 4500ish with a bbf
    I've got a mild 460 in a 20' jet boat 65 mph with diverter only at 5000 ft above sea level probably do 80 at sea level with more carb
    Oct 2010
    Lake Dallas TX
    Default Someone say Oldsmobile ? ? ?
    basically stock 455 in a 18' Kona 67 mph @ 4800 at 626 fasl A impeller JE pump
    Yucaipa, California
    Quote Originally Posted by hellnback View Post
    That's a little fast for an olds!
    1992 Eliminator Daytona 21'
    Senior Member Double A's Avatar
    Apr 2010
    Yakima, Washington
    What he said...and impeller?
    Chantilly Va.
    Default Hi 50s @ 4500 RPM 63mph @ 5300 RPM
    Sounds like a 150 shot to me on a Bone-Stock Southwind. Just sayin...
    Apr 2010
    Default 150 shot
    don't i wish, but then i'd be making the same complaint, only high 50s with 150 plate.
    C, no plate.
    Quote Originally Posted by Tahiti Boss21 View Post
    X2 clear the GPS once you unload the boat
    #55
