Altanator wiring????
Results 1 to 8 of 8
    Senior Member harley222's Avatar
    Sep 2009
    Default Altanator wiring????
    Does anyone have a wiring diagram showing how a one wire altanator is hooked up? Im running a AC Delco ALT and a silinoid(not attached to starter) and its not charging the battery, the alt is good and so is the battery..Any thoughts lol?????
    Aug 2010
    Quote Originally Posted by harley222 View Post
    you literally run the wire to the battery... i dunno how much simpler it could get.
    i made you a diagram:
    alt: ------------------------- battery
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    The thing to remember about 1-wire alternators is that they need a jump in RPM to "Excite" them into charging. A lot of times, just starting the motor and letting it idle doesn't do the trick. Try rapping the throttle and see if the voltage to the battery jumps up.
    Sep 2008
    OC, CA
    Run the alt one wire to the silinoid where the battery + cable from the battery hooks up. With this setup, you should be able to start the engine, disconnect the battery + cable at the battery and the engine should still run off the alternator.
    Sep 2009
    Thanks guys, i kinda had a idea i just wanted to make sure...If i didnt hook the wire to the silinoid and just ran the wire stright to the battery would that cause a problem?
    Senior Member FiberTEK's Avatar
    Jun 2011
    All posts above are great. I run my one wire to the starter post where the battery cable meets it.
    Sep 2008
    OC, CA
    You said that you are not charging the battery. By hooking it up to the silinoid you can check to see if the alt is putting out by disconnecting the battery cable at the battery.
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    I ran mine directly from the alternator to the +bat terminal on the starter. Ive ran it that way for years with no problems I personally think it makes for a cleaner look then a bunch of wires on the batt. Hope this helps, good luck!!
