Fuel pump question
Results 1 to 7 of 7
Fuel pump question
    anaheim hills ca
    Default Fuel pump question
    So i just put a new electronic fuel pump in, everything is tight a sealed but no fuel pressure, do i need to prime the system before i turn it on?
    Kingman/Golden Vly, Az
    m gonna say Yup, but, what do i know...i hate electric pumps! ...i have run a mech for yearssssss with n/p's ....just sayin'
    Senior Member motomattox's Avatar
    Apr 2011
    What type of pump? Also, remember that they are great "pumps", horrible vacuums! LOL Make sure that you help the pump out as much as possible to get fuel to it, in the way you mount it. It will have a much longer happier life.
    "Keep talking...it aint often I get to hear a genius speak"
    Quote Originally Posted by jmcracing118 View Post
    If it's not pulling fuel when you turn it on, just blow into the fuel tank to pressurize it a little an air compressor will work or just use your mouth to blown into the tank... the pump should pick-up then. Are you running a filter between the pump and tank?
    S CP
    anaheim hills ca
    If it's not pulling fuel when you turn it on, just blow into the fuel tank to pressurize it a little an air compressor will work or just use your mouth to blown into the tank... the pump should pick-up then. Are you running a filter between the pump and tank? S CP
    Yup im running a in line filter then a holly electric fuel pump then a canister fuel filter, ill try to pressurize the tank, thanks guys
    Aug 2010
    when i put all my hoses together i just filled my fuel/water seperator up with gas and then poured some into the hose before i hooked it to the carb rail. that way the whole thing wasnt completely dry. it sucked for a little bit but then you could hear it getting better and then finally good psi at the carb.
    Sep 2008
    OC, CA
    Quote Originally Posted by ka0tyk View Post
    Best way to do it, but make sure you filter the fuel when filling the fuel filter & lines.
