Electric Actuator for Engine Cover
Results 1 to 6 of 6
    Sep 2008
    Yuma, Az
    Default Electric Actuator for Engine Cover
    Is there a way to over ride the electric hatch? Mine decided to go bad with the hatch closed. I can get to it by lifting the back alittle, but figured there could be another way.
    Whitewright, TX
    Check to see if there is an access hole behind the rear seat back cushion. My Cole has them on both sides so you can reach in and remove the top actuator pins, allowing you to then lift the cover by hand. Jocko
    Sep 2008
    Yuma, Az
    I have access holes on the bottom. i was going to raise it from the back as high as I could and remove the nut holding the top bolt. and checking what other linear actuators you guys use. thx
    Senior Member sdpm's Avatar
    Remove the rear bench seat if possible?
    Apr 2009
    San Diego, CA
    Where my actuator meets the hatch cover I have have a quick release. See if you have the same before having to unscrew a nut.
    Sep 2008
    Yuma, Az
    Quote Originally Posted by sdpm View Post
    i'll try that tonight. thx
    Quote Originally Posted by WMorton View Post
    i screwed the nut on the bolt, but a quick release is a much better idea. thx
