[Question] How do I time my motor?
Results 1 to 5 of 5
    Arcadia CA
    Default How do I time my motor?
    So my timing of off and that's about all I know about this subject. I got a gun and I'm putting the boat on the water tomorrow but I want to time it right so it doesn't run like shit again. I think I set it to 6 degrees BTDC because someone told me to but I don't think that's right. Can anyone tell me what I need to do?
    Motor:
    14015445...454.......78-90...2 or 4 bolt main (I dont know which)
    353039.....454...cast (Crankshaft)
    14092360...86-90...oval...OPEN...454 Truck, "peanut" round ports
    RPM Air Gap with Bassett Twisties
    Holley 715cfm list 9049 Marine Carb
    MSD 8222 dist with a 6 series Box
    Berk JG-A
    Senior Member motomattox's Avatar
    Apr 2011
    Usually you would look for 10 degress btdc at idle, but to be honest, a boat doesn't run at idle. Set your boat at 34 degrees btdc at 3000 rpm. That way you lock out the advance. You might be able to put a little more advance in it depending on your specific motor, but you will have to play with it to see what it likes. Good luck with it.
    Motor:
    Berk JG-A
    You need to be more concerned with total timing than initial timing. Do you have a dial back timing light. You may want to try a search....think this has been gone through a few times.
    Arcadia CA
    Searching is no fun...that wouldn't leave anything for anyone to do except watch the PRF wars. Nothing like a good ole rehash thread
    Apr 2009
    San Diego, CA
    Try youtube for more visual explanation.
