Basset ot headers.to low
Results 1 to 14 of 14
    Jan 2010
    edmond ok
    Default Basset ot headers.to low
    I just got my engine set in and got my drive line angle right I. I went to put my new to me basset ot headers on well they hit the back of the boat has anyone had this problem?
    Jan 2010
    edmond ok
    I will try and get some.pictures when.i get home from.work
    Ladera Ranch
    Sounds like you need to go with a thru transom setup..
    Quote Originally Posted by mikeskustomkraft View Post
    Are they twisties ? or is the transom on your boat higher than most?
    S CP
    What Hull, what engine and what style headers did you order ? for example most mini cruisers and full grown day cruisers have too much transom height for standard headers Tom
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    You probably bought a set of Vdrive headers
    Jan 2010
    edmond ok
    There not twisties Its a.tx20 kustom kraft with a 468bbc im not really sure what basset headers they are they have the bells on em this boat has had ot headers on it before I got it
    Take a measurment from the underside of the header to the last header bolt hole , very likley as Todd said that you may have gotten V-drive headers Tom
    Senior Member Futs's Avatar
    Orange CA, Big River
    Quote Originally Posted by trg View Post
    you probably bought a set of vdrive headers
    bingo
    Jan 2010
    edmond ok
    Ok is there a way I can bend em with out messing em up I filled in the threw transom holes so im stuck with ot headers I can bolt em up but there toutching the fiberglass how much space should there between the headers and the boat thanks for all your help
    Jan 2010
    edmond ok
    The Man cordog009's Avatar
    East Texas
    Bending them isn't the best idea. I'd say try and sell them and get some for a jetboat. I agree that they sound like vdrive headers. Pics are worth a thousand words too. I'm not sure how you'd be able to bend them correctly and not have them messed up pretty badly. Not sure exactly what the min. amount of clearance should be, but the further away the better for sure.
    1984 Youngblood TX-19 SOLD
    Sep 2008
    Yuma, Az
    i had a boat that had about 6" of clearance from the header to the transom and i didnt burn the gel or paint. the splashguard was about 1/2" from the headers and i didnt have any issues with that either. how many inches of space do you have?
    boatless....
    Jan 2010
    edmond ok
    The passanger side is toutching and driver has 3/4"
