Sea Strainer on a Jet Boat
Results 1 to 14 of 19
    Anaheim Hills
    Default Sea Strainer on a Jet Boat
    Anyone ever done one?
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default No
    But I would/will in the future.
    Ever dismantle a motor, pull the freeze plugs?
    Hot spots due to silt/sand deposits built up over time.
    Loose, the Dogs of War!
    Anaheim Hills
    Yes I have and I was blown away by all the shit in the water passages after just 70 hours.
    I honestly don't know why you don't see these in more jet boats.. or any jet boats as I've yet to see one jet boat with a SS. Obviously one of the benefits to a jet is to be able to boat in shallow water. Shallow water is a big reason you pull up so much sand and derbies. So wouldn't a SS be the smartest thing to add?
    I heard that the pressure from the pump was too high for a sea strainer, however I run a water psi regulator so I don't see an issue.
    Senior Member wpmxwb's Avatar
    Jan 2011
    Long Beach, California, United States
    for the people that arent made of money and cant aford a $600 strainer would this one do a decent job?
    Amazon.com: Sea Dog 364136 POLYIN-LINE STRAINER-5/8IN HO POLY IN-LINE STRAINER: Sports & Outdoors
    Charlotte, NC.
    Quote Originally Posted by wpmxwb View Post
    I dont know but plastic shit scares me. just seems like there is lot of sun and heat and vibration back there and i would hate for that peice to go Tango Uniform while im running around. Then again maybe im just paranoid and it would work fine.
    southwindsforsure justsquirtin's Avatar
    Jul 2009
    rio linda calif
    just put one on to keep stuff out of the inner cooler
    Jul 2009
    rio linda calif
    couple of pics of plumbing=pressure relief -then strainer-set appx 18 lbs then to inner cooler then to engine
ID:	130355   Click image for larger version.
    New Jersey
    Plastic stuff shouldn't scare you, but ya still need to buy quality. That linked Sea Dog unit costs less than dinner at McDonalds.......expect problems with that.
    Quality plastic parts are a great way to beat the corrosion problems in marine systems and are pretty durable too but they aren't cheap.
    Doug
    Jul 2009
    rio linda calif
    that unit i put on was 130 thru mcmaster carr- has a drain cock on side of bowl - filter screen was to big - got some smaller mesh - will be going out wed to check and tune
    Senior Member LOLYFE's Avatar
    Idaho
    I use one that cp sells, more of a sand strainer I think, part number 620-4620, works great, and has a bypass if it ever gets clogged, and is high capacity. Never ceases to amaze me how much crap is in the water even though I am very careful about where I start it and run it.
    south,tx.
    I've made up a few sand strainers for me and some friends and they are working great.Using stainless steel filter(top notch),machined aluminum end plates,o-ring seal,and the all thread is threaded into helicoils.End plates are 3"x3",length is 6 3/8 inch.
    I'm testing them to 125 lbs.Also have been running one on my boat for a while with no problems.If anyone is interested i'll start a thread in the parts section.I have enough material for several more.I have material to make some bigger ones also.The one in the picture weighs in @ 1.15 lbs.
    Jan 2011
    interested. pm me with a price
    The Right Coast/SE-PA
    I've used this same strainer for well over 10 years...works GREAT! My inlet/exit ports are the next size up.
    Keep in mind I'm plumed one-line in, w/two dumps out the back, run a REX T-stat bypass, PSI never goes above 10lbs usually around 5-8 with good flow out the both dumps and zero chance of steam pockets in the heads.
    I also have my system plumed so there's another exact filter before the Bassett check-ball and spider lines.
    I do keep a spare clear spin on cover and stainless filter onboard > never needed it.
    CAUTION > this plastic filter WILL burst (if) exposed to higher water pressure, and did so in my brothers Jet > he had one line in/one dump out = too much psi!
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    I saw one in a boat this last weekend. It was the one you commonly see in v-drives. The guy told me he added it to keep crap out of the intercooler, said it worked great.
