Need Opinions!
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 55
Need Opinions!
    Lexington, KY
    Arrow Need Opinions!
    STAINLESS ROLLER ROCKER ARMS
    What do you guys think of these rocker arms? Little gun shy about buying from eBay, but the stuff that I have bought from this seller has always been very good quality, and it arrives next day to me because he is only in Tennessee.
    Thanks.
    HJ
    Senior Member wajetboy's Avatar
    Auburn, WA
    they look just like comps version
    1978 Southwind Tunnel Dragster/1980 SWTD center steer
    these might cure your valve cover clearance problem and a good price for a tested product.
    notice the corners.
    oh and you get what you pay for on those stainless ones IMO
    https://teaguecustommarine.c7.ixwebh...otcll5vo6jf770
    Lexington, KY
    Exclamation
    notice the corners.
    This statement on there is the only part that worries me about those,
    "May require modification of stock valve covers or rocker arm body for clearance."
    They are a very good price though.
    Thanks.
    HJ
    East Side
    Thanks.
    Why don't you start by buying the valve covers you need?
    Lexington, KY
    notice the corners.
    That's what worries me. But I don't really have a high horsepower or high RPM engine, so they not going to be tested under extreme conditions. Only worry is about the oil passages and stuff like that.
    Thanks.
    Quote Originally Posted by Some Kind Of Monster View Post
    I'm looking into that too. Just trying to cover all my bases. And get the most bang for my buck, without spending too much money.
    Thanks.
    HJ
    Senior Member hotbo's Avatar
    lake Ouachita AR
    hey fella i like the looks of them
    the problem you are gonna get is alot of guys will bash the overseas stuff.imo they will work just fine for what you are doing.just my.02 worth
    wouldnt it be cheaper to buy other valve covers
    Lexington, KY
    Only if I buy cheap stamped steel ones. And I just can't bring myself to doing that. I have tall sheet metal aluminum ones right now, but I'm having clearance issues with my stock style rocker arms.
    Thanks.
    HJ
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    Yeah, that makes alot of sense. Don't get the valve covers that work and will correct your problem (stamped or not), just change the more expensive sh*t inside and HOPE it works. Valve trains are a slippery slope. With new rocker arms, its probably a good idea to change your lifters and pushrods too......so there's more money.
    Race
    Southwest corner AR
    HJ I bought a set of Alu.valve covers from a speed shop I will see if I can find my info. They look good and were CHEAP !!!!! WT
    Coby
    Lexington, KY
    Exclamation
    ALUMINUM VALVE COVERS
    Ok, what do you guys think about these valve covers. Only problem with these is that I won't be able to use my aluminum T-handles and studs. Those pieces alone were like $70.
    I'm pretty sure that these will fit though, without any clearance issues because they are made wider.
    Thanks.
    HJ
    Default t-handles
    aluminum t-handles and studs may look cool but the first ski or mooring rope that gets near them "SNAP". That much leverage and the 1/4 inch studs just cant hang.
    pat
    FYI. Ive never seen a stock rocker interfere with any valve cover. sometimes the poly locks (if you are using them) hit but all roller rockers will be the same size or larger than the factory stuff.
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Why would there be a clearance issue with the stock rocker arms and a tall valve cover?
    Lexington, KY
    Ok, I'm gonna have to take some fuckin' pictures of this shit.
    They're hitting on the sides of the cover, not the top.
    Quote Originally Posted by gottaminute? View Post
    pat
    I didn't put them on there for looks. I put the on there because I got frustrated with tightening down all those bolts to get the valve covers on and off. Took too long, IMO. Also I am not running a ski tow on there right now. And I can't see much possibility of the rope going back that far, unless the skier is somehow up ahead of the boat. But, I might be wrong, I've never seen or heard of it happening.
    HJ
