Momentary Switch for Actuator (Engine Hatch)
Results 1 to 14 of 18
    Sep 2008
    Yuma, Az
    Default Momentary Switch for Actuator (Engine Hatch)
    Ive been looking for a 4-prong single pole, double throw momentary switch for my engine hatch. I find 3 prong switches everywhere. The uncommon thing about the switch is that it has to have a hot/ground and two momentary (up & down) prongs. I went to a few stores yesterday, including farm equip supplies & off-road stores looking for the switch with no luck. im sure the boat manufacturers know where to find them, but i cant. any help or link is appreciated.
    boatless....
    El Cajon , Ca
    Can't you use one from a hydrolic place diverter?
    Sep 2008
    Yuma, Az
    Quote Originally Posted by Marcsrollin View Post
    no.
    this is the closest thing ive found, as it has 4 prongs. it locks, so it wouldnt be good to have.
    boatless....
    What you can use is a Dual Pole Dual Throw(DPDT) "momentary on--off--momentary on" switch. It will have six terminals.You will have to add the two wires that cross over from bottom to top as it doesn't have the built in connections like the switch you posted. It will look like this when wired:
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    I have some 4 and 6 pole if you can't find any let me know! They are new!
    Feb 2010
    cant you just use the 3 terminal and 2 relays?
    1977 Charger 17Foot. jacuzzi golden eagle
    402 BBC tunnel ram with dual 660 fuel leaks on the top.
    Sep 2008
    Yuma, Az
    so the switch i posted will work once i wire how you have it? thx
    Quote Originally Posted by skippers WFOT View Post
    i could use a 3 prong and disconnected each wire when i need it to go up or down. just checking to see if i can find a switch like the one it has. thx
ID:	125059   Click image for larger version.
    boatless....
    Here's your switch. Cole Hersee 55054 Wire it like I showed above. You could also swap the positions of the B+/B- leads with the actuator leads and it will work the same. Do a Google search and you will find lots of sources to purchase from. You will also note there are a couple other versions of the switch on the Cole Hersee site.
    Dallas, TX
    Isn't that the same as this switch for a Place diverter? Just making sure I am not missing something here.
    PLACE DIVERTER Toggle Switch, Parts, place_diverter_hydraulic_switch
    Sep 2008
    Yuma, Az
    here is the switch for my hatch. (attached photo)
    ill try the 6 prong switch that i have. oldsquirter, thx for the help. i can see where the two ends are connected at opposite ends.
    boatless....
    Quote Originally Posted by YumaJet View Post
    Cole Hersee has that same style. I thought you were looking for a screw-style connection.
    Cole Hersee #55046
    Feb 2010
    5 wire alternating 12v. use the 3 pin switch and wire it up as the alarm output would suggest with a ground input on the center pole of your switch..put the relays back by the battery and you will only need to run 2 ground output wires to the switch from the relay bank(green and blue) this will keep all the current load from the switch, and eliminate extra wire runs. you could also add a contact style switch to the hatch to stop the actuaters at a preset location(magnet style or spring pressure contact.
    Senior Member buckjohnson's Avatar
    Aug 2009
    Biola CA
    Default Try these people
    products
    They have all kinds of switches! Ck with your local Electrical Disty!
    Sep 2008
    Yuma, Az
    Cole Hersee #55046
    ill order than tonight. i looked at different websites and 20plus google searches and you found. thx
    thx.
    here is my finished product. im adding a relay, but these switches were used on my old hydraulic set up, hooked up to 12 batteries, so one battery should be ok.
    boatless....
