Random Tach
Results 1 to 3 of 3
Random Tach
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Default Random Tach
    I have a SW tach in my boat. probably 20 yrs old. It sat in the old one and worked fine off a mallory dist. It sat for some time and now in my new boat with HEI it jumps all over. Sometimes it will stay at 3500 rpm after the key is off and then comes back to zero after you click it on again. Other times while driving it jumps all over. and then sometimes seems to work just fine. I checked the ground and it seems pretty solid. I know if you have the wrong cylinder setting it can cause this but it worked well in the old boat with a v-8. I also get inconsistant readings on my fuel guages. sometimes they are accurate and other times way off. Im not sure if my entire system is out of whack or what.
    Quote Originally Posted by mrjoshua View Post
    Was the Mallory a point type? possibly the Older tach is simply not compatible re your other guages , sd's like you may have a dash ground problem Tom
    Aug 2010
    Albuquerque NM
    Hey Tom. Yeah it was an old points set up. I have a terminal block under the dash with dual ground wires on either end and then daisy chained the interim terminals for the guage hook ups. whould this cause a problem? I thought it might just be too old and not be compatible with HEI. Like with most things i have little or no expertise and electrical is definately one of them.
