Can any one tell me what shoe I need?
Results 1 to 14 of 14
    El Cajon , Ca
    Default Can any one tell me what shoe I need?
    Just wondering if any one can tell me what shoe I need to order for my boat. Here is a pic of my intake.
    Atlanta, Texas, United States
    Quote Originally Posted by Marcsrollin View Post
    Well, quite frankly it looks like a little bit of everything has been bolted onto the back of that thing. What would be best is if you could tow her down to one of your local jet boat shops and let them look to see the condition of the mounting holes and see if they can fit you with a proper shoe and plate arrangment.
    Gear
    Shell Knob, MO
    We make a blank shoe that can be adapted to about any pattern of holes. It's about half way down on this page.
    Hi-Tech Performance : Other Performance Parts
    Duane HTP
    El Cajon , Ca
    In case you did not see it in the first post here's a couple more!
    031 RIVER4FUN's Avatar
    Why don't you just run it over to JP Marine?
    Southwest corner AR
    It will depend on what kind of HP you have and what you are planning on doing with the boat! Lake,River,Race,etc. That light weight hull would probley like a backcut or a flat shoe if you have the power for the flat! Tapered shoes work well on just about any TX!
    WT
    WFL Crew!!!
    El Cajon , Ca
    It was just a joke! The intake is coming out , MPD is making a loader and there is a new intake in shoe already in the works. It was more of " Look what some idiot did to this intake " .
    Ralls Precision Machine Ballztech's Avatar
    Mar 2010
    Default Dude!
    I found one with your name on it!
    You know, I was hoping you might consider that option. Good move. Jack will take good care of you. I have a stock dominator intake and was just about to consider offering it to you.
    El Cajon , Ca
    How much do you want for the intake? The one I got is a berkley and I would rather stick to the dominator.
    El Cajon , Ca
    Quote Originally Posted by Ballztech View Post
    You know I'm coming to you to get it all done!! Get to machining that focker!
    Mar 2010
    Default No problem.
    we have some other goodies for you as well..........Come on over a take a looksee.
    El Cajon , Ca
    Will Do!
    Senior Member lilrick's Avatar
    Lakewood
    hay thank for the crank info A$$hole!!!!
