Jet Boat Tech S. Orange Co., CA
Results 1 to 5 of 5
    Apr 2011
    Default Jet Boat Tech S. Orange Co., CA
    I am looking for a knowledgeable jet boat tech in So. orange County to check out a boat for me. I want a compression and leak down test done and visual assesment of the pump and hull. Any help is greatly appreciated.
    Thanks !
    Ron
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    You could call MPD (Marine Performance Design), not sure if he will do the compression check but he can look over the hull and pump.
    You could also check with CS19 here on the forums, he might do that type of stuff too.
    GS Marine maybe too?
    Ladera Ranch
    if its close enough to me Ill help you out. Not a pro by any means but I've rebuilt enough jet boats or been involved in them enough to spot most major problems. I have a compression gauge but no leak down and dont mind helping out. PM me if you are interested. Im in the Mission Viejo area...
    Anaheim Hills
    Go to MPD, Dave at DNE is next door to Jack.
    Sep 2009
    Red Mountain, Az
    Hey Cuz, just got your voicemail...been in the manroom getting the motor back together. I agree with these guys, Greg Shoemaker (GS Marine) and Jack McClure are both very knowledgeable and will take care of you. I will call Andy tomorrow and ask him to check with his buddies at Strut Marine/Paul Pfaff. I will be on Saguaro in the morning, but Ill give you a call after I run the new motor...hopefully I can make Parker on Friday :captain:
