holly blue or holly red electric fuel pump??
Results 1 to 14 of 15
    Junior Member johnkoopa's Avatar
    Jul 2011
    Riverside
    Default holly blue or holly red electric fuel pump??
    The fuel pump on my boat is a cheap Mr. Gasket 12d pump.. it is not enough to keep me at 2 psi at WOT.So my question is do I get a holly blue or holy red electric fuel pump?I have a dual carb set up on a 454... thanks guys
    Senior Member Lildave's Avatar
    Aug 2010
    Bauxite, AR
    Neither. Both of them will leave you stranded very soon.... Get a manual pump.
    Holley 130gph
    part# 12-454-13
    Mine failed on me several times when I had an electric pump. Starts every time now.
    Senior Member wildstreak's Avatar
    Feb 2009
    East Texas
    Default Manual pump??
    Quote Originally Posted by Lildave View Post
    Holley 130gph
    part# 12-454-13
    I would use a mechanical pump, dont think I want to try the manual pump. lol
    Aug 2010
    Bauxite, AR
    Lol ya got me
    Jul 2011
    Riverside
    Default mechanicle fuel pump rod froze?
    Lol ya got me
    Where can I get one of those Manuel pumps? We dont have thoes on the westcoast.. To be honest I only had the boat for about 3 weeks... it had a block off on the block where the mechanicle pump went.. I took it off and it seems like the shaft did not move.. but I never stuck anything in there to be 100 percent sure.. I found the old mechanicle pump and took it apart and it was all rusted and felt locked up..
    Electrical pumps are just fine....just run a relay. Have had the CP since '89 it has always had an electrical pump on it.
    S CP
    Jul 2011
    Riverside
    Default i will prolly just go with the holly blue with regulator..
    Thanks S CP, appreciate the input
    Redding, CA
    Quote Originally Posted by johnkoopa View Post
    Holley blue marine has been on our Miller for 5 years. Run a relay.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    The Earth
    Blog Entries
    24
    Do yourself a favor and get a Mallory Gerotor or Aeromotive pump. Holleys are not at all water tolerant. They work ok as long as they work. Any water through them and the vanes rust and then no pump. The rust then wipes out the seal and they leak or the extra friction burns up the motor. I've used several and learned this several times finally changed to Mallory and that was the end of that problem. Just my preference.
    The carter 4070 or 4594. The marine version is the same but about 30 bucks more...no need. Search Results for carter electric fuel pump - SummitRacing.com
    Made In The Shade
    Custom Window Tinting
    Senior Member lbhsbz's Avatar
    Long Beach
    Have you ever had issues with those pulling fuel from
    The tops of tanks (uscg approved tanks)? I had trouble getting a Mallory pump to prime unless it was below the tank....so I ended up always using holley's (plural...they don't live to long)
    Silverdale, Washington
    I've run the same Holley HP that Jon has in two boats and pull from the top without any prime problems.
    X2 on the relay (or is that X3?)
    Member apollo18's Avatar
    Jul 2009
    North East P.A. - Poconos
    S CP
    Im new to the electric fuel pump and i have the Holley red. so my question is what relay do i use for that?
    Jul 2011
    Riverside
    Default went with holly blue with regulator...
    works great!
