Knocking Noise, and no start when Hot help
    anaheim hills ca
    Default Knocking Noise, and no start when Hot help
    ok so this is the third time being towed in, shitty, so i hear a knocking noise from the pump and yes i disconected the driveshaft and the noise goes away so i know its the pump, and the noise increases with rpm, my other problem is i drive around and get everything warmed up shut it down and it wont restart, wait about 30 min when everything cools down and it fires up no problem, now i just replaced the entire fuel system including pump and filters, i checked and i have fuel and air but no spark. another thing is i mounted my coil directly to my head, is that getting to hot and causing it to stop working. idk so i have a horible knocking noise and a motor that wont run......and a river trip in two weeks help.........
    Jul 2009
    Hesperia California
    are you sure that your not getting water in the cylinders, water don't compress well! don't ask me how I know this. definitely move the coil, mount it off the engine if you can or on top of the manifold.
    If you have isolated you noise to your jet by removing the drive line from the "mix' then you have answered your own question and need to address the jet issue , seperate from that if your having a "hot soak" problem with the ignition its likley a component (CD box ,coil, ballast or distributor trigger possibly even an ignition switch , if you were to describe in detail the rest of the ignition (type brand etc , it might aid in the diagnosis Tom
    anaheim hills ca
    so i got the ich right after i wrote this i went and pulled the pump out im going to take it down to the shop tomarrow, as far as the no start, i have a msd 6a ignition, msd coil mounted to the head witch i will move,
