Place diverter Bennett pump problems
Results 1 to 3 of 3
    Sep 2009
    Red Mountain, Az
    Default Place diverter Bennett pump problems
    Just had the interior in my boat redone and now trim pump is dead. Worked just fine before new interior and wires don't look disturbed on trim switch or pump. Is there a fuse in the pump housing or any common problems with these? Not even attempting to pump...completely dead. Thanks in advance.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    check your switch, I would get a test light out and then go from there.
    Sep 2009
    Chicago, IL
    I'm having issues with mine as well, Check to see if the brushes are stuck.
