[Question] Water in the oil
Results 1 to 3 of 3
Water in the oil
    Aug 2011
    Tucson , AZ
    Exclamation Water in the oil
    So 2 years ago i bought my first jet boat,,,, went through it after getting water in the oil... its a 455 olds, and i am know aware of the existing problem with that motor ! Bran new rebuild on the motor and second time out same thing , im thinking the pump block off plate and timing cover... gonna throw some new ones at it . since everything was just magnafluxed. anyone got some advice or some personal experiances with that motor and problem ?
    Quote Originally Posted by CWAYNE View Post
    The most common places for these motors to have internal leak issues are (depending on exaust types) , Camshaft caused "reversion" issues , incorrect plumbing for headers or logs, intake manifold gaskets (wrong type vs manifold type) , excessive block pressure or as you suspected rusted/erroded or improperly sealed timing covers and water block off plates More info re your particular set up would be helpfull Tom
    Intake manifold, turkey tray gaskets = leaks.
    Pressure test the exhaust manifolds, they like to corrode at the riser/log flange.
    Reversion, induced by cam, or ineffective exhaust flapper.
