When do I need a 17-4 pump shaft?
Results 1 to 9 of 9
    Senior Member stewvette's Avatar
    Nov 2009
    Default When do I need a 17-4 pump shaft?
    I did a quick search but couldn't find anything on horsepower or rpm levels at which you need to upgrade the pump shaft. Is there a way to tell the standard and performance shafts apart visibly or otherwise?
    17-4 are the newer HP shafts, the older HP AQ's were magnetic, the old standard shafts were hard chromed for the bushing. Some where around 500HP is the number, mostly it's how abusive you are to the pump really determines the HP cut off.
    Quote Originally Posted by stewvette View Post
    Alot depends on what you will do with the boat , and like Chuck indicated ,how much HP , you may be surprized to find a modern high strength shaft is very comparable in price to a stock replacement shaft Tom
    Dec 2010
    Sapulpa ok
    I bet they will hold 900- 1000 hp as long as it isn't loading and unloading the pump
    Default shaft info
    chuck and tom have vast experience on these shafts and both gave good answers, my engineer book list the 304 as a yield strength of 31,200 psi and the 17-4 as 145,000 the elongation of 30% and 5% respectively, obviously the 17-4 is much much stronger, have seen some of the 304 twisted like a barber pole with 350 horse engines , this caused by jumping ways and slamming the impellor,, sledom see the 17-4 shafts damaged, like tom stated depends a lot on how you use the boat and if you are replacing the shaft not much difference in the price, if ever intended using bronze or stainless impellor the 17-4 is no where near as likely to warp.
    The Earth
    Blog Entries
    24
    17-4 is the magnetic material, it is very close to Aquamet's strength but substantially less $$.
    Nov 2009
    thanks for all the input guys.. I'm building 750- 800 horse blower motor and its going in a lake boat that will occasionally see some rough water so a better shaft will most likely be needed. I took a quick look at the shaft a magnet will not stick, so anything else i should look for to see if it might be an upgraded shaft being that the boat already had a blower motor?
    The Earth
    Blog Entries
    24
    You could have a metalurgist test the shaft. From a practical perspective if it was running for any length of time with the blower motor under load and didn't twist or break its likely not a stock shaft, more likely AQ (being its not magnetic). That isn't a guarantee certainly though. Lots of variables.
    Apr 2011
    Quote Originally Posted by johnray069 View Post
    If you do a mild H.T. you up the numbers more. I always recommended 500 H.P. as the base change point, which we also recommended Impeller change to Mag Bronze or S/S also a 7 to 9 pound Impeller increase also. Aggressors 17-4 had a Mild H.T. FYI
    As cost on Stainless went up we dropped all but 17-4 which also fit the newer bigger torque motors being produced. Cost became so close little cost advantage to produce the lower. The Aqua Marine shaft has much more carbon and less chromium content thus a lower twist strength. It's name came about as it was a special grind on the entire 12' bar with a much tighter tolerance on streight-ness over a 12' foot length for Prop Shafting, thus the additional cost.
