Water pressure regulator
Results 1 to 9 of 9
    May 2010
    SoCal
    Default Water pressure regulator
    So, i have a 455 olds in my Tahiti, and the last few weeks i keep seeing threads about all sorts of water issues resulting from to much pressure from the pump. Will a regulator from Home Cheapo do the trick? My boat is very mild, but I really dont want to deal with water in the oil and such. The motor has about 2hrs on it. On another note, im getting a small oil leak right where the head, the intake manifold, and block all come together. I was wondering if thats just a simple RTV fix? I heard that the valley pan and assorted gaskets around that area on the 455olds are notoriously leaky. Its such a small amount, but it makes a mess...any ideas would help. I really dont want to rip anything apart tomorrow night if I dont have to. My brother in law just said....add oil.
    Thanks again for everyone's help. You guys seem to help me through every issue Ive had, and I really appreciate it.
    Quote Originally Posted by My73Tahiti View Post
    Typically the pressure regulators from a hardware stores wont allow a low enough setting to work properly without internal modification suggest you stick with the proven kits , RE leaks from the Olds intake manifold front and rear sealing surfaces are very common on this series engine and we never use the supplied "cork or neopreme" end seals but rather we "punch peen" the seal surfaces of the intake and block "end seal areas" thoughly clean and then use a thick bead of a product called Permatex right stuff to seal between block and intake . you failed to mention which intake you have but any after market aluminum intake will not seal properly with the OEM "turkey tray" (designed for iron Automobile intake manifolds) and taht combo will eventually leak (water in oil too!) The main reason for oil leaks on these motors is inadequate crankcase venting/breathing and/or excess crankcase pressure (blow by,a multitude of causes) taking the path of least resistance, Suppose simply adding oil to the motor is an easy way to deal with this Call if we can help Tom
    IMO...put a water pres gauge on it. I was amazed how freekin much water pressure was going through my block with the valve off the jet wide open. I run mine about half shut...and still see about 20 psi plus at wot. On the oil leak...did you use rtv/sillycone or the rubber end gaskets for the intake manifold?
    Edit; oops looks like Tom types faster than I.lol
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    That "right stuff" is amazing not just a clever name. I use it on everything!!
    Default "IN" water
    I went through this question back in the 80s. I was told then, and most experienced jet riggers will tell you today, do not reduce the "IN" side water. If you're building too much pressure "dump" it on the "out" side. In thirty years I've never ran any type of "IN" regulator, never even looked at "IN" pressure, and with a couple exceptions, never had any internal water leaks in engines. If you reduce the volume of "IN" water you take a chance of creating "air" pockets in the engine that will lead to expensive failures. Maybe opinions and technology have moved forward, but my two running jets now are wide open, un regulated water supplies, without any leaks or milky oil.... Admittedly, they do run cold, and are probably leaving a "little on the bench" when it comes to power, but you never hurt them "cold" or "fat".... Hot, or lean, can, and does take their tolls. If you're milking the oil find out why and fix it.....
    Ray
    LOUD BOATS SAVE LIVES
    May 2010
    SoCal
    All, Thanks for the advice. I think ill take it to the "desert yacht" guy in Yuma and let him fix the intake leak(its a crosswind), and also see what the deal is about the water pressure. Thanks again.
    Bakersfield
    Do not reduce the "IN" side water. If you're building too much pressure "dump" it on the "out" side. If you reduce the volume of "IN" water you take a chance of creating "air" pockets in the engine that will lead to expensive failures. Admittedly, they do run cold, and are probably leaving a "little on the bench" when it comes to power, but you never hurt them "cold" or "fat".... Hot, or lean, can, and does take their tolls. If you're milking the oil find out why and fix it.....
    Ray
    Exactly! Well put Ray. Lean is mean, I found that out the hard $$$ way. Now it's fat, cold & happy...
    Dec 2010
    South Bay
    Wink
    Check out Watts Plumbing they have a pressure regulator that's perfect for you
    Part number XB-65 3/4 in an out.
    You can adjust it down to 20psi with a pressure gauge that screws on the end of it.
    I never have had water in the oil again.
    Plus it keeps the engine running between 135-150 water temp!
    Ray
    I get about 25+ psi at full throttle. I'm good....more than one way to skin the "plumbing cat" for sure.
