Haskal tunnel ????
Results 1 to 14 of 14
Haskal tunnel ????
    Colorado Springs
    Default Haskal tunnel ????
    I have found what we think is a 1980, 19' haskal tunnel hull with a hin of ....HMNT1336M801. The owner thinks it is an 83 but is not sure. It has a AT pump and has been converted to a BBC with a 512 block and Iron heads. The owner thinks it is a 427 but I imagine it is probably a 454. It has a very flat keel wich looks like a very long delta pad. The shoe sets lower than the keel. Any one know anything about the Haskals and if so how good of a hull is it and what is the good and bad. I thought I could add a dropped keel and set the pump back this winter if I bought it. Thanks in advance.
    Colorado Springs
    Default ???
    A gozillion views and no reply????
    Default haskell
    Quote Originally Posted by jungledave View Post
    try putting up a picture!!! I only know of a flatbottom with a runner bottom put on it with a jet
    Senior Member stokerdude's Avatar
    Jan 2010
    kingman Az
    must be the blue on that was on co springs craigslist...i saw that a while back...cool lookin boat...i dont know anything about them...ive been searching but i cant find anything...the add wont pull up anymore so i cant post a pic...ill continue to look for info but for the price he had on it you would probably be better off with a proven hull like a 19 daytona or a C.P.....just my .02
    come join the stoker owners and fans face book group
    http://www.facebook.com/groups/274764172561344/
    Jan 2010
    kingman Az
    found the add again heres a pic
    Colorado Springs
    Yes that is it. The gel looks good but the boat is going to take a whole winter to modernise. I was just worried about the flat keel before i started negotiating with the owner. Thanks for the reply
    Default haskell
    That is not a haskell, its a centurian or a brendella pickle fork,
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    looks Centurion to me also. most Brendellas had the rear wings on the sides.
    Colorado Springs
    Quote Originally Posted by Sleek Freak View Post
    Could you tell anything from the HIN at the top of my post. I am sure the owner has it right since it says Haskel in the Gell coat. I was wondering how good the flat keel tunnels work as a jet.
    Hooper Utah
    if its spelled Haskell like in the ad it should have a hin # starting HMW not HMN made from 6/3/75 to 3/1/83 in San Fernando Ca.
    Senior Member bwurst1's Avatar
    Nov 2008
    Roseville CA.
    What are yours plans for this boat (lake/race)? If its a lake boat i wouldn't worry too much about it. Ive got a delta pad (flat keel) on my Nordic. Last time I ran it at Bakersfield it ran 114mph @ a little under 10sec.
    Olympia, Washington
    Looks just like the bat centurian in spam, identical gel coat scheme except for the colors.
    Colorado Springs
    Your probably right on the HIN. I wrote it on a napkin so it could be a w. Yes and I knew I misspelled Haskel. thanks for the reply.
    Colorado Springs
    Quote Originally Posted by bwurst1 View Post
    Just a lake rod. Glad to hear a flat keel is working for you.
