Droop Snoot and ride plate
    May 2010
    SoCal
    Default Droop Snoot and ride plate
    So I have a 18' 73 tahiti with a mild(400hp) 455 olds and a place diverter. I can cruise at 27-30mph @ 3k RPM. I really dont feel like building the motor, as I dont want to lose what limited reliability I have with a 455, so I was thinking of building the pump. My goals are more towards cruising at lower RPM than all out top speed, but i admitt, its nice to go fast. With all that said, I am going to get the pump rebuilt, and Id like to add a droop and a ride plate,(the one that does not require any maching) as that seems to be the next step. Any input? Is it worth the coin? Anything else I can do? Also, my pump is a 12JC-A. I plan on sending the bowl to jetboat performance for the conversion to a split bowl. Like I said...any ideas for more efficiency would be greatly appreciated. Thanks for the help.
    Any Jet can benifit from a ride plate , some (not all) from a droop, although the "Bolt ons" are not exactly the same we have had no complaints from those who have chosen to go that way ... Tom
    Cole SS cole ss's Avatar
    Rochester, wa.
    I have a 20' cole which I modified like you are thinking. My engine is a bone stock 454, which really only puts out 300hp. It has a delta pad. I consider it a nice family cruiser. When I first got the boat it would only do 49 mph and had a porpoise problem at speed. I rebuilt pump. I added a loader which brought me to 54. I added a bolt on ride plate. This solved handling and porpoise problems. It made my boat think it was longer and brought me to 56mph. I then added a drop. This brought me to me to my top speed of 58mph at 4450rpm. With this set up I can cruise at about 27 at 3000rpm. Boat weights about 3000 loaded. I worked for me.
    May 2010
    SoCal
    Thanks all for the advice...I think when the season is over, ill make it happen. Ill get a good GPS [email protected] on the last river trip, then ill get the pump worked on, and see what happens...its only money right?
    bry
